Just installed e pump, need help!
Old Mar 4, 2012 | 09:01 AM
bashby's Avatar
bashby
I'm sure your pump is getting plenty of power through the relay, but maybe using the FSS to trigger the relay is causing the FSS to not get enough juce to open. If you unplug your relay and jump across the B+ and fuel pump terminals that would make the pump run without messing with the FSS circuit.
Old Mar 4, 2012 | 11:23 AM
tecgod13's Avatar
tecgod13
Originally Posted by tombogue09
Fuel shoots clean across my garage when I open that valve. I'll try the switch today and see what happens.
What pump did you use? What is the pressure its putting out? IIRC, the stock mechanical pump only puts out 5-7 psi, much more than that could be screwing with the pressure inside the injection pump.
truck won't fire. I unplugged the cold advance and broke all the injector lines. I let the ep run for 5 minutes and maybe half a drop came from one.
You shouldn't see any fuel come out of the injection lines unless the engine is turning. The injection pump needs to be turning to push fuel out to the injectors, the drop you saw would be any fuel left in the line from before.
Old Mar 4, 2012 | 11:39 AM
tombogue09's Avatar
tombogue09
Thanks tecgod! this was the problem. Everyone else probably thought that I had enough sense to know this but I didn't. Its obvious to me now and I feel so stupid. I haven't worked on engines much so i have alot to learn.
Thanks alot for all the help guys
Old Mar 4, 2012 | 12:00 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Thumbs up good call tecgod13
your going to find that the need to screw around with bleeding injection lines is a thing of the past.if you ever run out of fuel or change an ip,just crank.she'll fill the ip and fire off by herself in just 3 15-20 sec crank sessions under the worst case scenario now.
like tec explains,the e-pump can only do the pumping to your ip.your ip takes it from there delivering your high pressure.though as you just learned,only when running/cranking.
what's odd though is that your ip should have remained full during your lift pump swap and you shouldn't have run into this issue at all.
i guess what might have happened is that you thought you needed to bleed the ip,and rather than trying to simply start the engine once you swapped to the e-pump,you actually emptied it yourself by cracking some lines,and then cranking.
Old Mar 4, 2012 | 09:06 PM
tecgod13's Avatar
tecgod13
No problem, glad to have helped. The way I see it, everyone else was trying to fight over the right way to wire up a relay when you had the figured out.
Also, don't feel stupid, most people these days don't even know how to change a tire. Diesels can also be trickier than gassers since there are fewer of them, and fewer people that know how they work.
Just to be sure though, you got the truck running?
Old Mar 4, 2012 | 09:22 PM
tombogue09's Avatar
tombogue09
cracked the lines and cranked the engine, sure enough the fuel started spewing out. I tightened them back down, hit the starter, and it fired without hesitation. My brother was there making fun of me because his 12v cummins started. He stopped that when he saw the idi fire up as quick as it did. it only has 40k miles on it
Old Mar 4, 2012 | 09:59 PM
Aune163rd's Avatar
Aune163rd
Good to hear she is up and running!!
aje1535
22
Oct 1, 2016 06:56 AM
jwolfe60
Sep 6, 2007 01:14 PM
otter712
May 14, 2004 09:37 AM
tlc auto
17
Dec 5, 2003 09:32 PM
junkyard4$
Oct 21, 2003 10:55 AM
