Sponsored by: Real Truck
4R100 not downshifting
Old Jun 4, 2013 | 10:07 AM
kameronth's Avatar
kameronth
As you may remember I rebuilt my 4R100 a few moths ago. Today I was driving to a job site and about half way through I noticed that my truck was not downshifting. It will start in 2nd and shift all the way to OD but it will not downshift when I get my foot into it. If I downshift on the column it shifts just fine and goes all the way to 1st with engine braking. No CEL and O/D light is not flashing. It has been raining and my truck is pretty soaked. Maybe the solenoid wires?
Old Jun 4, 2013 | 05:22 PM
redford's Avatar
redford
FTE Leadership Emeritus
When you stop at a light or stop sign, and you do not move the gear selector from anything besides "D", does the truck start out in first gear?
Old Jun 4, 2013 | 06:28 PM
projectSHO89's Avatar
projectSHO89
All shifting (unless the lever is in 1 or 2) is controlled by the PCM. Hook a scanner up and look to see if the PCM has commanded the expected downshifts or not.
Old Jun 4, 2013 | 07:35 PM
kameronth's Avatar
kameronth
Yes but shifts to 2nd extremely fast.
Old Jun 4, 2013 | 07:40 PM
kameronth's Avatar
kameronth
There was no CEL but I was getting code p1120 for the throttle position sensor. I replaced it since its original and was only $25. Still the same issue. I'll have to see if a shop here even has time to run a full diag on the truck to get transmission codes. Everyone is slammed here.
Old Jun 5, 2013 | 07:16 AM
kameronth's Avatar
kameronth
Also, it does not do this about 10 percent of the time. If I shut the truck off for about 5 min and start to drive it will be fine for just a little while then start acting up again.
Old May 26, 2014 | 05:04 PM
kameronth's Avatar
kameronth
Update:
I plan on selling my truck this summer so I decided today I was going to take another shot at my issues since the weather has been warm. About 3 months ago my truck started to make a "whistle" noise under the hood. First thing I though was vacuum. I replaced the 90 degree pcv elbow coming from the throttle body about 4 years ago. At that time it had a hole and turned on the CEL. Power was down but still shifted normal.
Well, I fixed the issue. The 90 degree pcv elbow was collapsing in on itself when the truck got up to temp. Also, the pcv was not sealing properly. I replaced the elbow, pcv and tubing. It shifts great and no more whistle!
So none of the issues were related to my transmission rebuild.
Old Feb 22, 2021 | 02:19 PM
Prawna's Avatar
Prawna
I’m having this problem right now.
what does this mean the problem is? Thanks a ton!
Tesknox
May 7, 2023 05:45 PM
DAT2109
Nov 27, 2013 01:38 PM
codylt1
Nov 15, 2010 07:39 PM
lllateralus
Jul 26, 2010 03:36 PM
natewoz
Oct 25, 2007 01:36 PM
