Temp gauge in E4OD
Old Apr 30, 2003 | 08:22 PM
2Wise4aGM's Avatar
2Wise4aGM
Temp gauge in E4OD
I bought a tranny temp gauge for my 92 f250 with an E4od. Where is the best place to mount the sender where I will get a good reading?
Thanks
Mark
Old May 1, 2003 | 05:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Temp gauge in E4OD
On the driver's side, just above the pan and towards the front is a port with a 1/8" pipe plug. Remove the plug and install the sender there.
Be careful not to overtighten! Several people have broken the sender off in this hole.
Old May 1, 2003 | 07:09 PM
2Wise4aGM's Avatar
2Wise4aGM
Temp gauge in E4OD
Thanks a lot.
Old May 1, 2003 | 08:37 PM
James Hewett's Avatar
James Hewett
Temp gauge in E4OD
Now do you know where to go to find how hot you should let yur tranny get? or other oils breaking down from high temps?
http://performanceunlimited.com/directions.htmlnny ---- then click on Technical Questions.
I installed temp gauge with external filter, nice setup, but didn't kno what was to HOT.
Old May 1, 2003 | 10:57 PM
GeneStoner's Avatar
GeneStoner
Temp gauge in E4OD
Wow, does the C6 have a similar sender hole in it?
Man that would be nice!
