88 awd ?
Old Mar 3, 2012 | 05:02 AM
  #31
88dually's Avatar
88dually
cj, 4r70w, i thought 4r100's are mod motor an diesel tranny's
Like i've said before, if an exploder can be awd, why cant i try an make a full size awd ?
Old Mar 3, 2012 | 07:38 AM
  #32
ewalt98's Avatar
ewalt98
There are times, at least for me, where I'm in and out of 4wd just going to town. AWD would be much more convenient. In my 03, it's a simple switch on the dash. Its all manual in my 88. In our Subaru, you just get in and drive. I appreciate that on some of the crazy winter days.
My old Chevy was AWD, but my father put lockout hubs on it prior to me to get better mileage. It didn't help much....
Old Mar 3, 2012 | 09:15 AM
  #33
88dually's Avatar
88dually
I'm tryin to find out what will work
Old Mar 3, 2012 | 10:39 AM
  #34
Big_Al59's Avatar
Big_Al59
About 10 years ago I had a 79 chev 3/4 ton with the 203 full time transfer case. Drove it several years, in hi range you could drive at freeway speeds without any problem. Didn't notice A big difference in gas mileage +/- 1 mpg between the other 4x4 trucks I had at the time. Did notice you had to rotate tires more frequently or front ones would wear faster. You could also feel the 4wd a little bit if you had to do some full lock turns of the wheel when parking or turning around. Couldnt tell any real difference when using hi loc or Lo loc, was supposed to lock or equalize the transfer case output.
Old Mar 3, 2012 | 10:54 AM
  #35
f100beatertruck's Avatar
f100beatertruck
88, take a look at an explorer and take a look at a dually... Notice anything? The dually is bigger, can haul more and can tow more...
IMO a 4r70W, which is nothing more than the evolution of the AOD simply won't cut it. The 4r100 is the evolution of the E4OD. That's what you'll need.
I'm pretty sure a 203 case would bolt up. From what I know the NP208, BW1345 and BW1356 are all interchangeable between the C6, AOD and E4OD along with the manual transmissions. Those are the only cases I've been interested in but the NP203 was bolted to a C6 and can be swapped for a 205 and 208 as far as I know.
As for the later cases with the viscous center diff that I don't know.
Look here: Ford Transfer Case Identification
Old Mar 3, 2012 | 12:11 PM
  #36
Diesel_Brad's Avatar
Diesel_Brad
I want to say the AWD Explorer/expedition t-case is CLUTCH driven and Not gear or chain driven to allow slippage when needed.
I just dont see the need/want for a FULL TIME 4WD. It will wear parts faster and eat more gas because you are CONSTANTLY spinning wore parts.
You also have to remember the explorer and expedition use CV shafts NOT u-joints.
The reason you were feeling vibrations that night you were flying in the snow was due to the front axle shafts, it had NOTHING to do with the t-case. Sounds like you had a bad u-joint somewhere
Old Mar 3, 2012 | 12:21 PM
  #37
Phy's Avatar
Phy
The Explorer AWD T-case (at least the one in my '98 Exploder 5.0) doesn't lave low range, and doesn't lock. The NP203 has high, high-lock, low, and low lock. Being able to lock the T-case is sure worthwhile, at least to me...
You could also just leave your hubs locked, then you can switch between 2wd and 4wd on the fly with a part-time T-case (as long as you're not sliding, and going reasonable straight...)
Old Mar 3, 2012 | 12:40 PM
  #38
jk89cat's Avatar
jk89cat
only trick with using a 4r100 is none of them were ever offered behind a small block ford. you would need a e4od then upgrade the guts! btw if you do do this go with a 95+ e4od, alot better unit! the 4404 explorer tc would bolt up using the correct 4x4 extension housing .
Old Mar 3, 2012 | 12:41 PM
  #39
jk89cat's Avatar
jk89cat
brad your right, the explorer uses a viscous clutch setup in the t/c
Old Mar 4, 2012 | 07:56 AM
  #40
88dually's Avatar
88dually
Can the 203 case be made electronic instead of having a handle cut thru the floor ?
What is the loc part mean, u have 4hi, 4hi loc ? 4lo, 4lo loc ? My 2 trucks have 2h, 4h, n, 4lo
Old Mar 4, 2012 | 09:18 AM
  #41
Diesel_Brad
It doesnt matter what t-case you use. You will still have vibrations
Old Mar 4, 2012 | 11:24 AM
  #42
blkF250HD's Avatar
blkF250HD
Many AWD vehicles have CV axles going to the front wheels and a front driveshaft with a double-cardan joint. My Typhoon was AWD. It has a BW4472 transfer case with a viscous clutch differential. Zero vibrations, but it was designed to be AWD. I had to be mindful of the transmission since that thing made more torque than many V8s.
That said, if you're going 75 the conditions shouldn't be so poor as to need 4wd/awd. I see those people end up in the ditch usually. Another thing to consider, if you dont need to haul or pull, just get around, look into a used Subaru. By far the best AWD system you can buy.
Old Mar 6, 2012 | 04:30 AM
  #43
88dually's Avatar
88dually
Ok guys, thx for the helpful info, it sounds like a doable project with the right parts. The question is, do i wanna do it.
Old Mar 6, 2012 | 10:13 AM
  #44
Phy's Avatar
Phy
I don't think there was ever an electric shift set-up for the NP203.
That's for the NP203 T-case from the late '70s full-time 4wd trucks.
The T-case provided for differential action between the front & rear for normal high-traction conditions. The "loc", or lock, positions locked the front & rear outputs in the T-case together for low-traction conditions. In this mode, it's just like a current 4wd system.
Old Mar 6, 2012 | 10:22 AM
  #45
88dually's Avatar
88dually
Are 203's hard to find ?
Killgore
Offroad & 4x4
Feb 22, 2014 06:36 AM
muckypaws
Aug 18, 2004 07:44 AM
bolanrox
Offroad & 4x4
Apr 20, 2003 02:27 AM
havoc06432
Apr 16, 2003 06:32 PM
Robk1013
Feb 26, 2002 10:37 AM
