cps problem
Old Mar 2, 2012 | 08:20 AM
Shattered's Avatar
Shattered
cps problem
I had a problem with my CPS, and installed a new one yesterday, truck ran fine for a few miles, then acted up again. my local performance shop pulled the codes and it was the CPS. I cleaned the plug and connector port with elec. contact cleaner and applied some di-elec. grease. plugged it back in and it ran like a top. this morning it acted up again on my way to work. I noticed the wires for the cps had some very worn out elec. tape on them, could the wires have worn insulation, hence the reason for the tape? and if so could they be grounding out and causing this problem? if not where do I go from here? truck is a 99 7.3 psd
Old Mar 2, 2012 | 10:03 AM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Mar 2, 2012 | 10:34 AM
woodnthings's Avatar
woodnthings
Investigate the harness closely. That can easily be the problem.
Old Mar 2, 2012 | 11:34 AM
BillyBob69's Avatar
BillyBob69
Which CPS? Grey? Black? Blue? Where did you get it from?
I ordered 2 from Parts Guy Ed and both have served me well for a long time. I only replaced the first cause of another issue I had and I thought that was the problem but it wasn't. So now i have a spare in my glove box.
barkmulcher
23
Sep 2, 2011 01:14 PM
zack7.3
Sep 14, 2008 08:05 AM
Tailspin
Mar 21, 2008 08:27 AM
Kookadala
Mar 21, 2007 11:12 AM
Clint Knotts
Jul 9, 2006 12:03 AM
