I'm thinking a wiggle test would be a good place to start Ches. If you find a bad connection via that method, at least you'll be on the path. The other option might be a test light with a sharp probe end to check the wires into the fuse panel and the follow them back to the source.
Ches thanks for getting those straps back quick, they showed up this afternoon. I actually use those quite a blit.
In my room (Garage) trying to make room, getting things ready to go back into the shed, so I can bring a few things into the garage...
Its a long day when it starts at 04:30 and ends at 19:00 and I am on the flight schedule again at 05:15. So that means I have to get up at 0400 and go get my weapons at 430 and be at the helo at 04:45.
And to all a good night.......well from over here anyway.
Rich it sounds like you are more than busy. Playing in the garage trying to make some room. Un loading some junk that has been in the bed of Ka'Bluey all tarped up this winter.
wow you guys make me look bad..all i got donr today was get the front hubs offa a 59 pontiac wagon...then got about halfway thru geeting a list of parts from a 59 chevy 2dr. sedan..but couldnt get 4 bolts out without someone to hold backup..no room for vicegrips... i did the breaking up thing yesterday down in arkansas... boy i would rather take a whipping than go thru that again
I finally got a fan shroud that works perfect. ....I made one. Here's a couple shots of it while I was building it. I'll do the finish work and paint it tomorrow. Then on to the carburetor. I gotta get this thing outta here, but I refuse to rush it and turn out crap work. I already yelled at the guy for trying to cut corners and getting stuff that was gonna be inferior. Anyway, ....here ya' go....
With a name like that, it was probably a hot hues color. That should be easy to get. I'll see about it when I pick up the paint for my truck. (just to see how easy it is to get and maybe get the code for it)
Good Morning Everybody!
Gonna go look at another house today and get this fan shroud finalized. Probably fix the exhaust so it doesn't get in the way of the shifter too. .....and fix the throttle linkage.
