Connecticut Chapter Join Chapter, Leader:
March BS
Old Mar 27, 2012 | 06:52 PM
  #976
Nice Work Truck's Avatar
Nice Work Truck
Evening guys
It is nice when they stand behind a product like that Kyle.
Aaron what liner did you use, it looks good.
Old Mar 27, 2012 | 06:54 PM
  #977
Zookie400's Avatar
Zookie400
this stuff: Welcome to Liner Xtreeme
i used it on my truck, it came out great so ray got the same stuff for his. we will be doing my dads in the future as well.
Old Mar 27, 2012 | 07:24 PM
  #978
keyul's Avatar
keyul
It sure is Andy! Especially since it saves me $$$!
Did you buy the whole kit Aaron?
Old Mar 27, 2012 | 08:47 PM
  #979
acf6's Avatar
acf6
i almost wish i did that instead of spending $490
Old Mar 27, 2012 | 08:59 PM
  #980
Zookie400's Avatar
Zookie400
i used 2 "small" kits. 2 gallons of black stuff, 2 quarts of epoxy, and 2 bags of rubber.
the website has changed and seems to be incomplete, but if you call they know what you will need.
we used the large chunk rubber, but its pretty aggressive and not necessary for most people.
Old Mar 27, 2012 | 09:01 PM
  #981
Zookie400's Avatar
Zookie400
well this is NOT going to work for a flow bench. i guess i will need to redesign for a blow through style bench using rays big cummins powered compressor.
Old Mar 27, 2012 | 09:04 PM
  #982
acf6's Avatar
acf6
^ can you explain what that does to those who have no idea, like myself
Old Mar 27, 2012 | 09:17 PM
  #983
Canned Ham 450's Avatar
Canned Ham 450
its used to meter airflow while doing valve jobs, porting, etc on go fast motors. Volumetric efficiency type stuff. Used to help get optimum airflow.
Can also be used to test intake manifolds, throttle bodies, carbs, air filters. Anything that needs fine tuning for air flow
  #984
Canned Ham 450
To put it in basic terms
Old Mar 27, 2012 | 09:35 PM
  #985
acf6's Avatar
acf6
nice, thanks, stuff that goes fast is always cool
Old Mar 27, 2012 | 09:51 PM
  #986
jthorngate3's Avatar
jthorngate3
That's the vacuum gauge we used to tune my carb actually.
Old Mar 27, 2012 | 10:05 PM
  #987
Zookie400's Avatar
Zookie400
its like a wind tunnel. it measures air flow through engine parts (or other things) and is what all serious engine builders need to properly shape ports for optimum performance.
the goal is to keep the ports as small as possible while getting the most (or most appropriate amount) airflow through the port. the flow bench allows you to see all the changes in air flow when you reshape the port/exhaust/intake or whatever you want to test.
AEM Flow Bench Demonstration for Cobalt SS CAI - YouTube
Old Mar 27, 2012 | 10:08 PM
  #988
acf6's Avatar
acf6
cool! So you could use it to test something like airflow through stock vs. K&n filter?
Old Mar 27, 2012 | 10:09 PM
  #989
Zookie400's Avatar
Zookie400
yes sir it is!
for accuracy, 20+ inches is ideal, anything above 10 is good enough for monitoring changes rather than getting exact numbers, the dust collection system would only pull .5 in/h20
shop vac's can pull some great vacuum but i would need 5 of them inline to get the CFM i need without a pressure drop.
Old Mar 28, 2012 | 04:22 AM
  #990
rocdril's Avatar
rocdril
Morning everyone!
