zf s560
Old Feb 29, 2012 | 10:26 PM
okwaho1650's Avatar
okwaho1650
Red face zf s560
will a zf s560 ( 6 speed ) work on my 300
Old Mar 1, 2012 | 09:00 AM
AbandonedBronco's Avatar
AbandonedBronco
No, the bolt pattern is designed for a different engine series. However, there may be an adapter available, but I've never heard of one.
A ZF 420/470 5 speed will, though. (Just make sure it's designed for a 4x4 and for a 300/302/351)
Old Mar 1, 2012 | 10:29 AM
okwaho1650's Avatar
okwaho1650
Smile
y 4x4 i have a 2x4 how easy r hydro cluches
Old Mar 1, 2012 | 10:48 AM
AbandonedBronco
Oops, sorry, I'm used to dealing with Broncos only, which are all 4x4.
I should have said, be sure to find one that's the same setup as yours. 4x4 or 2x4.
Old Mar 1, 2012 | 02:44 PM
sufferingant's Avatar
sufferingant
just go to a junkyard and get everything you need from a truck that already has the hydro setup. I'd recommend a new slave cylinder because it's internal and the trans has to come out if it goes bad, but other than that it's not bad.
I think you'll have to switch your pedal set to ones that came with a hydro setup, here's a link on how to replace the bushings inside the pedal box, but this will also apply to pulling the pedal assembly out;
92 F150 4X4 won't start w/ clutch in and hard to shift - Ford F150 Forum
Old Mar 1, 2012 | 05:58 PM
F-250 restorer's Avatar
F-250 restorer
Here is what you need.
Dan1971
Nov 6, 2012 05:26 PM
95bronc5spd
Jun 13, 2007 09:06 PM
scottr408
Jan 27, 2007 07:58 PM
mikeyswood
Dec 27, 2005 04:39 PM
