Sponsored by: Real Truck
TPMS solution needed
Old Feb 29, 2012 | 06:40 PM
ABF PSD's Avatar
ABF PSD
I have a 2008 F250 FX4 CC that I recently traded my 2005 SD in for. I am looking for a solution to the TPMS transmitter. My truck didn't have one in the glove box. I rotated my tires and need to reset the light. Does anyone know where I can get one cheaper than the dealer, they want around $60 for it and it looks cheap as hell. Is there and after market one that might work or is there any other way to reset the light without this transmitter.
Thanks,
John B.
Old Feb 29, 2012 | 07:00 PM
critterf1's Avatar
critterf1
There should be a procedure out-lined in your owner's manual to alleviate this problem.
Old Feb 29, 2012 | 07:06 PM
dualwheels66's Avatar
dualwheels66
I am pretty sure the dealer is the only place to buy them. However if you bought it from a dealer, tell them it was not in the truck at the time of purchase and they might give it to you. I'm sure if you go to the dealer to get the TPMS reset, it will cost you more than $60.
Old Feb 29, 2012 | 08:41 PM
LaredoF350's Avatar
LaredoF350
What air pressures are you running?
Someone can correct me if I am wrong, but i vaguely recall that the F250's didnt come with the TPMS reset unit, just the F350's?
It has to do with the higher weight rating and rear tire pressure to accomplish this on the F350...
Old Mar 1, 2012 | 10:28 AM
ABF PSD's Avatar
ABF PSD
I am running 65 PSI. When I rotated them I guess the pressure was just enough off to trip the light. My F250 deffinately has the monitor, I haven't ever heard that only the F350's had it.
Thanks,
John B.
Old Mar 1, 2012 | 12:36 PM
LaredoF350's Avatar
LaredoF350
The F250's have the TPMS (except the Job 1 trucks). The sensors are all at the same pressure on an F250; however, the F350 has sensors set to a higher pressure on the back axle than the front axle. There is a procedure (on F350's) to 'teach' the system when you rotate tires...
Old Mar 1, 2012 | 03:15 PM
smotrs's Avatar
smotrs
Thanks,
John B.
Oh it has the monitor, what he's saying though is that the F250's have the same rating front and back so there was no need for the reset tool.
Old Mar 1, 2012 | 04:00 PM
Sebs's Avatar
Sebs
My 2008 F250 does not have the same pressure for front and back and it came with the transmitter. It is supposde to have 65 front and 75 rear but I can run 65 on all four without tripping the TPMS. Your best bet if you don't want to buy the transmitter is to borrow a buddies. It only takes a couple minutes to reset.
Old Mar 1, 2012 | 08:06 PM
Quad Racer's Avatar
Quad Racer
Just ignore the light.
Old Mar 2, 2012 | 09:28 AM
smotrs's Avatar
smotrs
You must have the camper package, only reason I know of for the difference front to back.
Old Mar 2, 2012 | 09:37 AM
Sebs's Avatar
Sebs
No camper package unless it's the same as the tow package.
Old Mar 2, 2012 | 11:09 AM
richsoucie's Avatar
richsoucie
sears has the tool in the auto shop they probly wouldnt charge much if you brought it there also if you buy your tires from them with road hazard protection they will rotate them and do the sensors for free
mtnguy
Apr 23, 2017 09:10 PM
67DART
6.7L Power Stroke Diesel
Dec 28, 2015 01:07 AM
superfast bob
6.2L V8
17
Apr 11, 2012 09:30 AM
Hubbardlaker
Jun 22, 2010 06:04 PM
DD2000GT
Feb 14, 2008 07:51 PM
