Removing Power Steering Pump...
Old Feb 29, 2012 | 04:16 PM
el cheapo's Avatar
el cheapo
Hi all,
I want to remove my power steering pump, and get a serpentine belt that will fit my 97 2.3 liter ranger. Problem is, NAPA says there is only a e belt to fit a ranger with NO power steering and NO air conditioner.
I guess I will just remove pulley from compessor to make the belt work without it, and with the power steering pump off.
Can anybody foresee issues with this? I may even just remove the whole compressor if it isn't too difficult. The steering rack leaks where the hoses go in, and I never looped the hoses so the pump has been running dry for 1.5 years now, and is starting to seize.
Thanks
Steve
Old Feb 29, 2012 | 04:37 PM
Phinxter's Avatar
Phinxter
If you make this work I want to see a pic of this setup.
Old Feb 29, 2012 | 05:56 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
97 Ranger has a steering gear mounted on the LH frame rail powered by a power steering pump that is belt driven. Can't you just add p/s fluid to the pump reservoir?
Old Feb 29, 2012 | 07:14 PM
critterf1's Avatar
critterf1
Why not just fix it?
Old Feb 29, 2012 | 08:44 PM
el cheapo's Avatar
el cheapo
Well a steering rack is close to $200, a new belt is only $30. Plus time to install a steering rack is much greater that a new serpentine belt.
The fact is I have been driving this truck wih no power steering since I bought it 2.5 years ago, i don't need the power steering.
I could add some steering fluid to the power steering pump but honestly I want more of a long term fix, without having to buy a new steering rack of course.
Any help in this matter is greatly appreciated!
Amicus
19
Nov 17, 2018 08:47 AM
LeroyB3000
Aug 27, 2008 02:10 PM
RangerPilot
Mar 11, 2006 11:09 PM
Godder
Dec 31, 2003 01:06 AM
