over drive light blinking, drives fine??
Old Feb 29, 2012 | 02:48 PM
amreynolds's Avatar
amreynolds
2002 Mountaineer:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Driving into work today, my over drive light started to blink very fast. I have not had any trouble with high RPM's or shifting. <o></o>
I live in MN and we had a very rainy/slushy/snowy drive in and never went faster than 30 miles per hour.<o></o>
Could an ice or snow build up be the culprit? I sure hope so!<o></o>
Thanks for any advice in advance.<o></o>
Anna<o></o>
<o></o>
Old Feb 29, 2012 | 07:07 PM
critterf1's Avatar
critterf1
Could it have been over heating due to blocked tranny cooler?
Old Feb 29, 2012 | 07:14 PM
KhanTyranitar's Avatar
KhanTyranitar
You need to take it to a transmission specialist and have it looked at. It might be nothing, but if your trans is slipping, the computer can detect it long before you can. How many miles since your last trans fluid change?
Old Mar 1, 2012 | 07:23 AM
projectSHO89's Avatar
projectSHO89
Could have been any number of things. Until you get the fault code(s) read, it's pointless to guess.
Old Mar 1, 2012 | 10:16 PM
Fordzilla80's Avatar
Fordzilla80
As others have said, have the codes read. The scanners at Autozone can't touch Ford Transmission codes, so you need to find someone with a higher level scanner, or take it into a transmission shop to have the code read. Come back with the code and a description of what happened before the O/D Off light started to flash, and then we can see what we can do to help you.
Old Mar 2, 2012 | 07:17 AM
amreynolds's Avatar
amreynolds
Thanks, It was doing nothing different when the light came on. I have the airbag and asb light on also. Does that make a difference? To be honest I am buy a new car. I am not auto handy and the nickle and dimeing gets old.
Thank you all
Anna
Old Mar 2, 2012 | 11:00 AM
Fordzilla80
In all honesty, if you have higher mileage, it is probably best that you get a new car. Rebuilding transmissions has become quite pricey these days.
Old Mar 2, 2012 | 03:06 PM
amreynolds's Avatar
amreynolds
Thanks, I did.
Diesel Submariner
Apr 24, 2011 07:04 AM
brickie
Mar 10, 2008 10:14 PM
firstrider
Mar 5, 2008 08:54 PM
bigtexan99
Apr 12, 2007 09:55 PM
