cel and codes help
Old Feb 29, 2012 | 01:42 PM
stainlessstroker95's Avatar
stainlessstroker95
cel and codes help
I was driving me and my dads 96 f350 welding truck yesterday and it lost power for a split second and threw the cel. After that the truck ran fine. I scaned it today and got p0603 pcm processor kam error next was p0344 cps circuit intermittent error and last was p1211 icp above/Below desired. Truck is a 96 f350 with 109k on it. Bone stock. Would the cps being bad cause the icp code? Thanks guys.
Old Feb 29, 2012 | 06:12 PM
JamesHajek's Avatar
JamesHajek
Nope. First one is from disconnecting batts, last one is just what it is, an ICP # that the PCM didn't like for whatever reason.
Replace the CPS though...
Old Feb 29, 2012 | 08:03 PM
stainlessstroker95
I wonder what would make it spike or drop down. I will change the cps though.
Old Feb 29, 2012 | 08:46 PM
F350-6's Avatar
F350-6
P0603 and P1211 are two of the most popular codes on any truck that is chipped or has a tuner on it. I'd say both of those codes are likely caused by the Edge and will continue to show up, and should be continued to be ignored.
Old Feb 29, 2012 | 09:34 PM
oldbird1965's Avatar
oldbird1965
I went a couple of years with the 1211. I changed the ICP and it didn't help. I learned, like Chris said, to ignor it. My last reburn stopped it, so far, knock on wood.
Old Feb 29, 2012 | 09:44 PM
stainlessstroker95
thanks for the replies. This is on another truck i have not the one in my sig. I just use the edge to check codes. The truck this happened to is all stock and has not had a chip or programer on it. I wasnt getting on it when it happened, just cruising at 55.
Old Mar 27, 2012 | 06:45 PM
stainlessstroker95
Just an update. Left the house yesterday to go to a welding job and a quarter mile from the house truck died. I thought it was out of fuel but it wasnt. It was just like you shut the key off. So i let it sit for a couple min and it fired right back ran for a min and half then died. I got it back home and scanned it and got the same codes as stated earlyer. I went and got a cps from ford and it has solved my problem. Maybe this will help some one. I still need to get a spare one for it like i have in my 95.
Old Mar 27, 2012 | 08:19 PM
f1501987's Avatar
f1501987
How much was it? And were is the cps at?
Old Mar 27, 2012 | 08:21 PM
fordpride's Avatar
fordpride
I think the icp code came when the truck drop rpm's fro a split second and pick back up and you foot still being on the go pedal
Old Mar 27, 2012 | 08:50 PM
stainlessstroker95
That would make sense mike. It is located on the front of the motor bottom left if you are starring at the front of the truck. Easy to change you just need a 10 mm wrench. It was bout 32 dollars from ford. And for what its worth the bad one i took out had a black oring and the new one was purple.
Old Mar 27, 2012 | 09:05 PM
oldbird1965
Its been awhile but isn't it about 9 or 10 o clock position?
Old Mar 27, 2012 | 09:54 PM
ReBilld's Avatar
ReBilld
Hey Gabe, you pull your codes with a scangauge right?
Old Mar 27, 2012 | 10:59 PM
stainlessstroker95
Yes that is right glenn
Old Mar 27, 2012 | 11:23 PM
stainlessstroker95
My scan gauge is mounted in my 95 and i do scan codes with it. But on the 96 i just use my edge evolution to pull codes.
Old Mar 28, 2012 | 11:36 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Actually its at 11 o clock.
https://www.ford-trucks.com/forums/1...-sensor-2.html
