CHANGING OIL
Old Feb 28, 2012 | 07:21 AM
Rob_in_Alberta's Avatar
Rob_in_Alberta
CHANGING OIL
Wondering if it is essential that my truck be completely level to do an oil change? Any disadvantage if one end is 10 inches or so above the other (on grade)? Thanks,
Old Feb 28, 2012 | 09:47 AM
dchamberlain's Avatar
dchamberlain
As long as the drain plug is down, you will be OK draining the oil.
You will not be able to get an accurate oil level check on the dipstick unless the truck is level, though.
pete/ny
Feb 19, 2012 04:02 PM
BELLBEAR
Apr 25, 2010 06:03 PM
thaefele
6.4L Power Stroke Diesel
Jan 3, 2009 11:06 PM
stevestroke01
Aug 11, 2008 05:18 PM
hammer toe
Oct 1, 2007 08:44 AM
