scanguage II codes
Old Feb 28, 2012 | 12:30 AM
kbuchheit's Avatar
kbuchheit
scanguage II codes
I got my scanguage and hooked it up. I went to program the x codes and see that you need tons of info to do it. Can anyone tell me which codes I definately want in there? I know I want FICM volts, temps, boost, egr and a few others. Does anyone have a sheet with all of the values listed by chance?
Thanks in advance for any help!
Old Feb 28, 2012 | 12:40 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
The Scangauge website has quite a few, if those are not enough:
Here you go.
https://www.ford-trucks.com/forums/1...l#post10227382
And a video entering Xgauges.
Scangauge II Xgauge entering - YouTube
Old Feb 28, 2012 | 12:42 AM
kbuchheit's Avatar
kbuchheit
Awesome! Thanks! Which would you recommend besides those I listed?
Old Feb 28, 2012 | 10:30 AM
amdriven2liv
Well, where to start.
First, if you are OCD, the Xgauges scroll from #24 to #0.
So, I entered mine alphabetically. From 24 to 0. Makes it easier to find them.
I also have both ICP gauges, IPR % to help trouble shoot HPO issues.
I have all 3 FICMs
The DTC count is good to have. It will show when you have a pending DTC.
BAR, EBP, Fan speed sensor., MAP
What do I run?
In the mornings I will have ECT, EOT, FMP (FICM main power) Volts
Towing:
ECT, EOT, TFT, Fan speed or boost. ( I have an 04 which does not have boost gauge)
Boost showed me one day I was losing boost. Found my blue CAC tube had shredded.
Every once in awhile I will show DTC count just to check. Your new SGII should have a way to check for these, mine is an older version and doesn't have these.
By the way, in the thread of gauges I posted, there are many gauges that have the operating values under each one.
Old Feb 29, 2012 | 12:25 PM
kbuchheit's Avatar
kbuchheit
Thanks a bunch!
It sounds like I use my truck about the same as yours. I have noticed that loud howl when towing and assumed it was the fan, now I will know for sure.
I will enter the codes tonight and start getting readings to evaluate.
Thanks again!
grantpage
Sep 12, 2012 03:55 PM
ol-blu
Jan 28, 2012 09:34 PM
ford4x4956
Nov 7, 2011 10:26 PM
Rushmore X
Jun 13, 2011 05:00 PM
Fluid Power
Jun 22, 2009 06:50 PM
