Whoops! Not Good!
Old Feb 28, 2012 | 08:41 PM
mblanken881's Avatar
mblanken881
Whoops! Not Good!
Some of you may have read my 'Leak' thread:
https://www.ford-trucks.com/forums/1142837-leak.html
Well, I found the leak. Not good! Oil is leaking at the oil pressure sensor I just replaced. It appears that when I installed the sensor, I must have cross threaded it. The sensor was finger tight. I pulled it out to find that the threads were stripped clean. Threads appear fine on the sensor but the threads on the truck side are messed up bad!
What do I do? Can you just buy the part the sensor attaches? If so, whats the part number and how much?
Old Feb 28, 2012 | 09:16 PM
jl4407's Avatar
jl4407
I'm not sure but you might be able to tap it, I'm sur you will find the help you need here. These guys are awsome, helped me threw a oil cooler replacement.
Old Feb 28, 2012 | 09:18 PM
mblanken881
There's nothing to tap. The threads are gone halfway down in the hole in the plate.
Old Feb 28, 2012 | 09:19 PM
BLADE35's Avatar
BLADE35
Man that sucks
All I can think of is a new oil cooler housing
Thats one part I wouldnt want to Jimmey Rig cause if it blows apart its going to dump oil FAST
I guess the Catch 22 to that is if it did lose Oil the truck would shut off before anything got damaged because it wouldnt fire the Injectors without any HPO
Aluminum ya right I wont even use a Torq wrench on that stuff anymore
Old Feb 28, 2012 | 09:20 PM
BLADE35's Avatar
BLADE35
Theres whats called a Helicoil tap it big and run a Sleave in it But I wouldnt trust it if it failed you will be stranded
Old Feb 28, 2012 | 09:21 PM
mblanken881
Where do I get a new oil cooler housing, how much, and how difficult/how much time to do?
Old Feb 28, 2012 | 09:31 PM
jl4407's Avatar
jl4407
When I was shopping for my oil cooler I ran across a few on eBay that were new, not sure how much they were, I'm sure blade35 has the part #. Its a little bit of work to get to it and someone corect me but if your in there u might want to just chance the oil cooler out, just my 2cents
Old Feb 28, 2012 | 09:34 PM
BLADE35's Avatar
BLADE35
Ford for parts unless you can find someone that has it left over from a BPD setup
Its going to require you to change the oil cooler out so maybe a couple days if you havent been in there B4
would be a great time to install a new oil cooler if spreads out of spec
But basicaly an oil cooler job
Old Feb 28, 2012 | 09:38 PM
BLADE35's Avatar
BLADE35
Oil Cooler Kit - Entire cooler, Housing and all Ford 3C3Z-6A642-BB International 1843068C97
"The Ford part number is the new design oil cooler (an extra cooling row)
The International Part # is for the old design oil cooler"
the first number is Ford second is international this is from one of marks lists pretty recent one so Im hoppen its the right part #s
mblanken881
should i just do an egr delete while i'm in there?
Old Feb 28, 2012 | 09:42 PM
zhilton's Avatar
zhilton
That's usually what gives away a LPO failure after one has eating needle bearing from a failed lifter.
The only part number I've been able to find is this:
3C3Z-6881
But there should be a two letter suffix behind a second dash. Tousley lists one for $500...but I'm not sure if that's a complete cooler & housing or just the housing. You might fire off a PM to nccpartsman...I know he's got an extra (complete assembly) one for sale. Should fit an '05 and up truck going off the top of my head.
Old Feb 28, 2012 | 09:43 PM
jl4407's Avatar
jl4407
I got my oil cooler from the dealer, they told me over the phone it was just over 350.00. I went in after work to pick it up (in uniform) and they gave me a law enforcement discount that brought it down to 278.00. So check withe the dealer and see if they will come down at all.
Old Feb 28, 2012 | 09:51 PM
m-chan68's Avatar
m-chan68
Actually, the part number posted by BLADE35 is now obsolete. You can no longer purchase an entire oil cooler assembly from Ford. The part you are after, is the oil filter adapter plate (the part that the oil/fuel filter housing, EOT sensor, EOP switch and turbo oil supply tube attach to), which I believe is part number 3C3Z-6881-AA if I recall correctly. The part number for the oil cooler KIT is part number 3C3Z-6A642-CA which includes the cooler core, along with the screen under the oil cooler and all the o-rings and gaskets needed for the install. You will need to transfer and re-use the oil cooler top cover for this repair.
Old Feb 28, 2012 | 09:54 PM
BLADE35's Avatar
BLADE35
If you want an EGR Deleate then Now is the Time for shure
I havent come across a Part # for just the housing yet
Last time that I checked Tousley Ford had just the oil cooler for 215.00 they are also a site sponser now so
If you can let it go Tousley will be your best bet unless somebody has one left over
I would also get a Turbo Hardware Kit to and Intake gaskets now Intakes are reusable but you have to get them out without damage but not to bad
<TABLE style="WIDTH: 438pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=584><COLGROUP><COL style="WIDTH: 221pt; mso-width-source: userset; mso-width-alt: 10788" width=295><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 585" width=16><COL style="WIDTH: 110pt; mso-width-source: userset; mso-width-alt: 5376" width=147><COL style="WIDTH: 95pt; mso-width-source: userset; mso-width-alt: 4608" width=126><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 221pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 height=17 width=295>Updated oil drain tube</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl70 width=16></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 110pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 width=147>6C3Z-9T515-A</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 95pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl69 width=126>1876071C91</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 height=20>04 oil feed tube</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl70></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67>3C3Z-9T514-A</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl69></TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 15pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 height=20>06 oil feed tube</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl70></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67>3C3Z-9T516-A</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl69>1845287C96</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68 height=17>04 -07 Turbo gasket kit (ie no cleaning kit)</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66>3C3Z-9T514-AG</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67>1840053C96</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 343pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=458><COLGROUP><COL style="WIDTH: 221pt; mso-width-source: userset; mso-width-alt: 10788" width=295><COL style="WIDTH: 12pt; mso-width-source: userset; mso-width-alt: 585" width=16><COL style="WIDTH: 110pt; mso-width-source: userset; mso-width-alt: 5376" width=147><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 221pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68 height=17 width=295>04 Intake manifold gasket</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 12pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 width=16></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 110pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66 width=147>3C3Z-9433-AA</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68 height=17>05 Intake manifold gasket</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67>3C3Z9433BH</TD></TR></TBODY></TABLE>
Old Feb 28, 2012 | 09:57 PM
BLADE35's Avatar
BLADE35
He stripped the oil cooler housing where the Oil Pressure sensor went
So Mike if you have a good fix for that you might could save him a bunch of work
never mind I gotcha
the part number you have is for this peice right????
3C3Z-6881-AA
