extreme camber changes
Old Feb 28, 2012 | 12:07 AM
mudbogger93's Avatar
mudbogger93
i got a 1990 f150 with a new six inch lift kit, new pivot bushings, new wheel bearings, and new ball joints, and new radius arm bushings. driving foward and then backing up its having some extreme camber changes wondering what this might be. i dont believe i torqued the wheel bearings enough but i dont think it would cause that big of a change. its going to a alingment shop as soon as i get the time to get it there. just wondering what it might be.
Old Feb 28, 2012 | 07:36 AM
White Max's Avatar
White Max
I'm not certain what your definition of extreme is, but the camber change you describe when reversing is common to the TTB front axle.
Old Feb 28, 2012 | 10:43 AM
Conanski's Avatar
Conanski
Lifts and larger tires tend to exagerate the "normal" camber changes seen with this suspension system. It's a good idea to inspect your lift and make sure the brackets aren't moving since this will further exagerate thigs, and if there is movement you may have to weld the brackets in place.
Old Mar 1, 2012 | 10:10 PM
mudbogger93
the wheel bearings weren't torqued right and the upper ball joint on the passenger side was really lose but got it tightened up and everything looks alot better
EgoMan
Apr 11, 2007 01:04 PM
bg95f150 with bipolr
Nov 19, 2006 06:55 PM
gatorpsd
Jan 11, 2006 05:20 PM
nelly781
1978 - 1996 Big Bronco
Dec 9, 2005 03:17 PM
rhetor
May 13, 2004 07:45 PM
