vacuum problem?
Old Feb 12, 2012 | 01:40 PM
Adamjmerideth's Avatar
Adamjmerideth
vacuum problem?
Alright, I've got a 89 250 351/c6 4x4. My concern is that I have low Vacuum pressure. I my trans has a lazy shift to 3rd with a brand new modulator. and think it might be due to low pressure I measured it at 16lbs from the upper plenum at idle (650rmp or so) and as i gave it throttle it would go up to about 19lbs is this (to spec)?
PS the truck likes to stall right after a cold start without some pedal is usually fine after about 1 minute though. I suspect this might be related to a possibly low vacuum maybe? the stalling isn't really my concern just thought the info might help.
Old Feb 12, 2012 | 02:39 PM
f100beatertruck's Avatar
f100beatertruck
How many miles do you have?
Also is the ready steady or does it fluctuate? If it fluctuates, by how much?
It's normal for the gauge to read higher when you rev it quick. It should return to your baseline after a quick bit.
Old Feb 13, 2012 | 09:46 PM
Adamjmerideth
Both numbers hold steady it does spike but then levels at 19lbs
Old Feb 13, 2012 | 09:53 PM
SCRebel's Avatar
SCRebel
How about pull the vacuum line off the modulator and stick your finger over it. Your vacuum line might be cracked. Also if you gas the engine, Like floor it, you should lose vacuum, then it should come back.
Old Feb 29, 2012 | 07:36 PM
Adamjmerideth
alright so i took a hand operated vacuum pump and all the line tested good except the egr witch would not hold a vacuum. but capping the line made no difference in pressure.
Old Feb 29, 2012 | 07:39 PM
Adamjmerideth
Also i went around the whole engine compartment with an unlit propane torch and found no difference in idle.. PS I pulled some codes and a TPS and a MAP sensor code any thoughts?
Old Mar 1, 2012 | 07:31 AM
rla2005's Avatar
rla2005
Your vacuum levels sound about right. I do not think that has anything to do with your transmission issue. Has the transmission always exhibited this behavior? Have you checked the transmission fluid level? When was the last time you changed the fluid and filter?
What are the numerical codes and when they were displayed? i.e. during the KOEO tests, KOER or CM?
The stalling during a cold start is more than likely caused by a dirty or faulty IAC (IAB). Here is some info on this piece: Fuel Injection Technical Library » Idle Air Bypass (IAB)
Old Mar 1, 2012 | 06:48 PM
Adamjmerideth
so i read up on iacv and when i unplug it the truck stalls but i took it apart and cleaned it and put on a new gasket still stalls... so no luck there. the fluid levels are good just rechecked but fluid and filter where changed about 1000 miles ago.
The code numbers are 22 and 23 one is tps out of range and the other is map out of range thoughts?
Old Mar 1, 2012 | 07:09 PM
blkF250HD's Avatar
blkF250HD
I'd fix the TPS and MAP issues and go from there. There should be 0" of vacuum at WOT, or 14.7psi of manifold pressure (atmospheric).
Old Mar 1, 2012 | 10:31 PM
rla2005's Avatar
rla2005
X2
cabloom300
28
Dec 2, 2014 11:08 AM
SteevenH
1997 - 2003 F150
Jan 24, 2011 10:08 PM
shelton
20
May 16, 2008 08:21 PM
dagray3
Dec 26, 2007 01:21 PM
FordandSkeeter
Jan 28, 2005 09:03 AM
