53-55 and 56 steering box differences?
Old Feb 27, 2012 | 12:09 PM
chappys4life's Avatar
chappys4life
I have a 53 f100 now but have a spare complete 56 steering column. Could I rebuild the 56 and swap it in? What are the differences?
Old Feb 27, 2012 | 02:47 PM
da_catt's Avatar
da_catt
the 56 has a shorter steering shaft and column. I think the steering wheel is different too. I have what must be a 53-55 box in my 56 because I have about a 1 inch gap between my steering wheel and column.
Old Feb 27, 2012 | 03:13 PM
chappys4life
Okay that makes sense I thought it was shorter but was not sure if using a 53 wheel would cause issues. Guess I am on the hunt for a box then or pulling mine.
Old Feb 27, 2012 | 05:31 PM
raytasch's Avatar
raytasch
Believe Nothing
The 56 has a dished steering wheel so that may mandate a different column length.
Old Feb 27, 2012 | 08:16 PM
55 f350's Avatar
55 f350
catt is right and if you want to run a custom wheel or another factory wheel of some type with a dish geuss which one you need ...............other wise your stuck with a flat wheel or the wheel stuck in your face ........... 56 is 2 inches shorter if i remember right .
Old Feb 27, 2012 | 10:29 PM
chappys4life
I like the flat wheel as it has the 50th anniversary logo think its a cool point about the truck
Old Feb 29, 2012 | 12:05 AM
old ugly's Avatar
old ugly
Hi ,
My parts book shows that the 56 steering shaft is 1 3/4" shorter than the 53-55 steering shaft. I believe you could probably use the complete 56 box and column as long as you also use the 56 outer tube. The 53 steering wheel should fit onto the 56 shaft but it will be 1 3/4" further away from you. Maybe a good thing if you have a big belly or if you have short legs and can't reach the peddles. The 56 is probably shorter to make up for the dished steering wheel.
I don't think you have anything to loose by trying it.
Good luck.
Old Feb 29, 2012 | 04:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The wheel has no logo, it's on the horn button. But...only the 1953 horn button has the 50th anniversary logo (1903/1953). 1954/55 horn buttons do not.
TAAA-3524-A .. Steering Shaft & Worm-42 3/4" long / 1953/55 F100/250.
B6C-3524-A .. Steering Shaft & Worm-41" long / 1956 F100/250.
TAAA-3504-A .. Steering Gear Assy / 1953/55 F100/250.
B6C-3504-A .. Steering Gear Assy / 1956 F100/250.
TAAA-3548-A .. Steering Gearbox Housing-Only, no internal parts / 1953/56 F100/250.
B6C-3575-A (replaced TAAA-3575-A) .. Sector Shaft / 1953/56 F100/250.
TAAA-3509-A .. Steering Column Outer Tube (Mast Jacket) / 1953/55 F100/600.
B6C-3509-A .. Steering Column Outer Tube (Mast Jacket) / Use with remote control gear shift / 1956 F100/350.
B6Y-3509-A .. Steering Column Outer Tube (Mast Jacket) / Use with center shift transmission / 1953/56 F100/250 & P350/600.
AFAIK, 1956 is different due to the wrap around (knee-knocker) windshield.
Wildcat Fords
Apr 29, 2017 09:35 PM
willowbilly3
Jan 22, 2013 05:38 PM
mark63uni
1961 - 1963 F100 Unibody
Mar 6, 2012 08:35 PM
1964FORD4ME
Feb 16, 2006 03:50 PM
Mats Nilsson
Oct 24, 2004 06:20 PM
