Steering Column 1964 F100
Old Feb 16, 2006 | 11:52 AM
1964FORD4ME's Avatar
1964FORD4ME
HELLO EVERYONE
I HAVE BEEN TOLD THAT THE STEERING COLUMN AND THE GEARBOX ARE ONE ASSEMBLEY. IS THIS TRUE AND IF SO WHAT CAN I DO TO CHANGE MY COLUMN?
THE STEERING WHEEL IS TO CLOSE TO YOU WHEN YOU ARE DRIVING.
THANKS FOR YOUR HELP
JASON
Old Feb 16, 2006 | 01:06 PM
John D.'s Avatar
John D.
I have a '63 F100 and my column just sits on the steering box with a rubber gasket in between.
John
Old Feb 16, 2006 | 01:27 PM
1964FORD4ME
Ok Thanks. I Was Wanting To Change My Column To Something With Tilt. I Was Told That A 84 Toyota Camary Power Steering Box Will Work On The 63 & 64 I Will Soon Find Out. Thanks Again .
Jason
Old Feb 16, 2006 | 02:24 PM
garbz2's Avatar
garbz2
The box and shaft are integral to each other. the steering wheel cannot be moved down or up. The outter collum cover and shift tubes encase the SOLID 5/8" Shaft. Thats why old timers call them widow makers in a frontal collision.
A camry box will not work as it is a rack n pinion type. The Steering box swap is a toyota mid eighties front steer four wheel drive box. Look up No Limit Engineering, they have a fat fendered toyota conversion kit that can be adapted to slicks 61 to 64.
Garbz
Old Feb 16, 2006 | 02:43 PM
1964FORD4ME
Talking
Ok. Thanks For Your Info. I Have A 1984 4x4 Toyota Parts Truck. I Knew If I Asked The Pros You Guys Would Know Thanks Again ....
Jason
Old Feb 16, 2006 | 03:02 PM
garbz2's Avatar
garbz2
Sweet!
Call Ron at NL he can help with the correct steering arm and parts including the collum.
Garbz
Old Feb 16, 2006 | 03:50 PM
drof46's Avatar
drof46
I'm a healthy guy and I want a shorter column also, but has too many other projects. A quick fix I'm considering is an aftermarket steering wheel. I think stock is 18" od. I'm looking at a 15 1/2 od wheel. That will give an extra 1 1/2 inches aprox of space/clearance.
DoggedTired
13
Jun 24, 2024 05:16 PM
HELL-ROD
Jan 28, 2015 07:10 PM
vze2c2gb
Sep 21, 2014 03:47 PM
SonyResendiz
36
Sep 18, 2014 11:37 AM
connvicted64f100
Aug 7, 2014 07:46 PM
