Houston, I have a problem.
Old Feb 26, 2012 | 10:29 PM
Furniture Doctor's Avatar
Furniture Doctor
Today when I was merging with traffic and had to jump on it to get out of the way of heavy traffic I experienced a flat spot during acceleration. I had to take my foot of the pedal and when I pushed it again the flat spot was gone but a cloud of blue smoke came out of the tail pipe. Is this a sign of a bad injector or a clogged EGR valve? I would appreciate your input.
Doc
Old Feb 26, 2012 | 10:34 PM
glovemeister's Avatar
glovemeister
We have no EGR valves. Was your truck warmed up when this happened? If it was cold and the exhaust back pressure valve was closed it could cause a problem like this. Any idle issues? Access to a scanner that can do buzz or cylinder contribution tests?
Old Feb 26, 2012 | 11:29 PM
JamesHajek's Avatar
JamesHajek
No on the EGR valve for sure since we don't have one. How many miles on the truck. Have you changed your fuel filter lately? Any oil inside the fuel bowl?
Old Feb 27, 2012 | 07:44 AM
Furniture Doctor
Flat spot
I was driving about 15 minutes. The engine was reasonably warm. I have not checked the fuel filter lately. I need to do that. As to the scanner, where do you plug it in? I have one for the car, will this work?
Doc
Old Feb 27, 2012 | 09:45 AM
Oldsmoky92's Avatar
Oldsmoky92
It plugs in on bottum of dash pass side of hump or stick shift if manual. I couldnt tell you if the scanner will work if it is OBD 2 it should.. Just depends on what years it covers. I had mine scanned at Ford for free, but i dont know if they do that for everyone.
Old Feb 27, 2012 | 09:56 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Doc
Most scanners dont work in our PSD, it has to have the specific ford PSD bundle (spl?).
Old Feb 27, 2012 | 10:03 AM
Oldsmoky92's Avatar
Oldsmoky92
Ok thanks RÖENTGEEP, my neighbor has a Snap On scanner that works really well.
Old Feb 27, 2012 | 10:38 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
You are welcome. Just curious where that number came from? its the first time I see it.
Old Feb 27, 2012 | 11:58 AM
Furniture Doctor
Houston calling
I just checked the fuel reservoir and it had clean fuel in it. The fuel filter was changed about 3,000 miles ago. The scanner that I have will not plug into the connection. The truck has almost 160K.
Doc
Jrj4379
Oct 12, 2016 11:59 PM
StrokinWarmblood
Sep 19, 2011 01:40 PM
TMartinLVNV
Jul 8, 2009 07:01 AM
bismic
Apr 19, 2008 11:55 PM
tmcoy34
Dec 13, 2003 07:48 PM
