85 f250 4x4 conversion question
Old Feb 26, 2012 | 09:43 PM
85250diesel's Avatar
85250diesel
Hey guys im new on here, names Daniel. I have a 85 F250 6.9 diesel with a 4 speed tranny and 2wd. Im wanting to make it 4x4. Ive found a 91 F250 thats 4x4 but has a inline 6 with a 4 speed behind it(tranny is shot). My question is will the transfer case and everything bolt up from the 91 to my 85? Im not swaping trannys, just wanting to add the transfer case and front end to my truck to make it 4x4. any advice is greatly appreciated!! thanks!
Daniel
Old Feb 26, 2012 | 11:51 PM
kedwinh's Avatar
kedwinh
Welcome to FTE.
Quick answer is no, it wont bolt up to your 2wd trans without an adapter. I don't know if the front axle will bolt up or not, but I would think it should.
Old Feb 27, 2012 | 09:14 AM
85250diesel
Thanks for the reply! The adapter youre talking about, would it be an adapter for the spline gears to mesh up or something, or would it be a metal plate with the correct holes to bolt the transfer case to? Would you happen to know if the adapter can be bought? Sorry about all the questions, im a little bit of a newbie when it comes to the drive terrain.
Old Feb 27, 2012 | 09:18 AM
85250diesel
And as far as the front axle, im planning on drilling/cutting to mount it in because my 85 f250 has coil springs and id be swapping to leaf springs off the 91 f250.
Old Feb 27, 2012 | 10:43 AM
kedwinh's Avatar
kedwinh
The adapter would be to convert the output of the 2wd trans so the transfer case would bolt to it. Probably be cheaper to pick up a 4wd trans from the junkyard.
Old Feb 27, 2012 | 01:58 PM
85250diesel
Alright, thats what i needed to know, thanks!
Old Feb 27, 2012 | 07:09 PM
Franklin2's Avatar
Franklin2
There is no 4x4 "adapter" to convert a 2wd trans to take a transfer case. Yes, a 2wd trans can be converted to accept a transfer case, but it needs to be torn down completely, and the correct parts installed inside the tranny, so it's just like a total rebuild of the trans, plus some parts you need also. It is easier to get a 4x4 tranny. The transfer case you are getting with the truck will bolt on though, once you get a 4x4 diesel tranny.
You are correct, the 4x4 frontend will need some drilling for it to fit, and also the front of the frame will need a little bit of welding and or brackets to fit the shackle. You will see what I mean when you look at the donor frame in the front area.
Old Feb 27, 2012 | 07:52 PM
85250diesel
Alright, thats a big help. Thanks!
Old Feb 27, 2012 | 07:58 PM
dyingtolive's Avatar
dyingtolive
OP, you could also run a divorced transfer case behind your 2WD transmission. If you have the necessary skills to drill/cut/weld things to put the leaf sprung front axle in, you've got the skills to fab up transfer case mounts/ a crossmember. I'd do that with an NP205 transfer case. But that's just me.
Just sayin'.
Old Feb 27, 2012 | 11:40 PM
85250diesel
So the NP205 transfer case doesnt bolt directly to the transmission? Im assuming theres just a shaft that runs from the tranny to the transfer case? And yeah i believe i could make a crossmember.
Old Feb 28, 2012 | 05:49 AM
ctubutis's Avatar
ctubutis
The transmission output shafts are different 2WD vs. 4WD.
Old Feb 28, 2012 | 09:31 AM
dyingtolive
Well, NP 205's of the divorced variety don't bolt directly to the transmision. And you basically hit the nail on the head. The nice thing about divorced transfer case is the ability to run just about whatever transfer case you want to run, and it makes clocking them so much easier.
Here's an illustration.
Old Feb 28, 2012 | 02:58 PM
Franklin2's Avatar
Franklin2
With the divorced transfer case, one thing leads to another, and I do not know if it's worth the headache. You have to figure and scratch your head on everything, the mounts, the shifter and it's linkages, even the driveshafts will have to be custom made. If you get the correct tranny, the tranny/transfer is a bolt in with the correct factory parts.
troy_dee
Jan 16, 2013 11:30 AM
MrJessimo
Sep 29, 2011 09:25 PM
lcox8551
Apr 2, 2011 07:00 PM
Fidishund
Sep 27, 2010 02:26 PM
mxer201
Offroad & 4x4
20
Dec 10, 2001 09:02 PM
