fuel guage
Old Feb 26, 2012 | 09:06 PM
jeff14346's Avatar
jeff14346
fuel guage
73 f250 cs, fuel guage works intermintantly, been using axillary tank, just got vehicle running, removed 2wire connector at sender cleaned off corrosion on terminals, truck has been sitting for 12 plus years
looking for ideas,
thanks
Old Mar 4, 2012 | 06:35 PM
jeff14346's Avatar
jeff14346
still looking forn source of problem, one time I drive, guage is not working, another time it works, checked fuel tank switch, has power,
please help looking for ideas
thanks
Old Mar 4, 2012 | 08:08 PM
HIO Silver's Avatar
HIO Silver
Pull the wire from the sender and short it to ground. Observe and report back what the gauge reads.
Also, do a visual inspection of the sender's wiring... Wiggle it around too.... could be a kink that intermittently opens or closes.
Old Mar 4, 2012 | 08:48 PM
J ballan's Avatar
J ballan
My truck sat for about that long and I had to change both sender wiring pigtails. They had green corrosion inside the connector.
Old Mar 4, 2012 | 10:44 PM
jeff14346's Avatar
jeff14346
thanks for the info, will try it tomorrow and let you know
Old Mar 5, 2012 | 12:51 PM
jeff14346's Avatar
jeff14346
2 wires going to fuel sensor, connected-shorted the 2 together, turned key on, guage full swept from empty to full, tells me a bad fuel sending unit
thanks
tchopper1969
Jun 30, 2011 01:48 PM
KiwiFord
Jan 13, 2011 04:22 PM
69ford99
1978 - 1996 Big Bronco
Mar 5, 2007 03:44 PM
tskinner
Jun 27, 2005 10:29 PM
redeye rye
Electrical Systems/Wiring
Nov 11, 2002 03:02 PM
