HPOP Trouble!
Old Feb 26, 2012 | 08:28 PM
beanhead6D5's Avatar
beanhead6D5
HPOP Trouble!
I have been having trouble with long cranks and poor fuel mileage.Over all my truck has just not been running right.I did some checking with my AE scanner and found that the Hpop was not putting out the pressure and the duty cycle was through the roof. 2250psi and 85% duty cycle,that was in 80E with a DP turner.
Here's what I found when I pulled the modded 17* from TE
The front seal was come out of housing.
You can see were seal was rubbing against the Hpop gear.Good think I deciced to pull the pump when I did.
Just glad I gained the knowledge of FTE to help me figure out what was wrong.
Old Feb 26, 2012 | 08:37 PM
jkidd_39's Avatar
jkidd_39
It was obviously your DP Turner being out of blinker fluid. Send me the Hpop, chip and $6000 and I will have the truck good as new in 4-6 months
Old Feb 26, 2012 | 08:46 PM
F350-6's Avatar
F350-6
I think that's one of the reasons Joey quit doing the modded 17 HPOP. Simply doing slight mods to an existing pump left too many issues that could or would fail, or would simply not perform well enough.
So what flavor HPOP are you going with now? And ignore Andrew. I can do the same thing for $5,500.
Old Feb 26, 2012 | 08:47 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Nice heads up Brad. That would definitely scavenge some HPO pressure and cause the duty cycle to soar.
Did you have your's redone or send it in as core and get a different one back?
Old Feb 26, 2012 | 09:47 PM
Pitcrw6's Avatar
Pitcrw6
Thats some good troubleshooting there.
Old Feb 26, 2012 | 09:48 PM
Bonanza35's Avatar
Bonanza35
Good find. AE paid for itself that time.
Chet
Old Feb 27, 2012 | 05:38 AM
bfife's Avatar
bfife
still plays with trucks
Nice catch Brad! I would think a new seal and some loctite would fix you back up. Might stake the outside of the seal slightly also.
Barney
Old Feb 27, 2012 | 05:51 PM
beanhead6D5
Going with a Stealth SRP1.1
I was in on a core swap a few of use guys did! Yes I did get a different pump,but it was a good pump.I think Pat (Justanothertruck) has my old pump.
Barney
Not for me! going with a whole new pump.
Old Feb 27, 2012 | 07:19 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
If you have Pat's pump then give him back his and take your's from him.
1bigjoe
25
Dec 28, 2016 09:46 AM
cens
Mar 22, 2015 06:08 PM
WA.Ranger
65
Feb 22, 2011 03:00 PM
WA.Ranger
30
Jun 10, 2010 01:46 PM
Stewart_H
36
Jun 10, 2010 12:50 PM
