Opti-Lube response
Old Feb 25, 2012 | 07:10 PM
cford716's Avatar
cford716
Opti-Lube response
I mentioned in another thread that I emailed Opti-Lube concerning if it meets Ford's specs. Here is their response:
My apologies for the delayed response.
I can not say for certain whether or not our products would void your warranty. However all our products are certified for use at fueling stations. Meaning you could get already treated fuel at the pump, because of this it should not affect your warranty.
Please contact us with any other questions.
Many thanks,
Raina, Customer Service Manager
801-491-3717
Opti-Lube
I guess without knowing what Ford's "specs" are it's hard to say. Not sure you would even get a clear answer from Ford if you asked them what the specs are that they are referring to in the manual.
Old Aug 16, 2022 | 01:26 PM
speakerfritz's Avatar
speakerfritz
does ford have an "opti-lube" additive tester?
Old Aug 17, 2022 | 11:51 AM
Pugga's Avatar
Pugga
What were you trying to determine? I'd expect you'd get a similar answer out of any of the major additive companies.
Old Aug 17, 2022 | 12:23 PM
jollyrogr's Avatar
jollyrogr
I've used opti-lube in every tank of fuel since the truck was new.
Old Aug 19, 2022 | 10:36 AM
slowmans's Avatar
slowmans
I have used opti lube in my 6.0,6.4 and now my 6.7 religiously and have never had any issues.
Old Aug 19, 2022 | 11:56 AM
speakerfritz
have you ever drained any water?
i use opti as well. They claim to be a deemulsifier, which is supposed to remove water . Over the last 8 years, never any water in the seperator.
Old Aug 21, 2022 | 01:24 PM
jollyrogr's Avatar
jollyrogr
I have never found any water. Could just be that my fuel didn't have any water in it.
Old Aug 21, 2022 | 04:34 PM
FishOnOne's Avatar
FishOnOne
I haven't found any water in a few years, and I don't use any additives.
Old Aug 24, 2022 | 08:10 AM
slowmans's Avatar
slowmans
I have never had any water issues, maybe a drop or two. I usually drain into a clear container and let it settle a few days and check. I can only recall seeing a couple drops once or twice.
Old Aug 24, 2022 | 03:30 PM
Compression-Ignition's Avatar
Same. Where do you live? Most of my diesel driving has been done in the northwest over the last 18 years. Just a few drops. I always wonder where this bad fuel is coming from that people are draining out all this water.
wpnaes
Kansas Chapter
1028
Jan 11, 2021 08:59 AM
mustangmatt
Feb 17, 2012 08:13 PM
88-150
53
Feb 5, 2010 08:29 PM
Nat LMMC CT
Connecticut Chapter
Jul 27, 2007 11:44 AM
fastbass_85
Nov 11, 2004 11:57 PM
