need decode help please
Old Feb 25, 2012 | 04:09 PM
66crawler's Avatar
66crawler
120 A f260 e81 f b4
F26CK470554
Thanks guys
Old Feb 25, 2012 | 05:10 PM
66crawler's Avatar
66crawler
The PO. also gave me a 1964 Ford shop parts manual an chiltons manual and a new harness for the entire truck.
Old Feb 25, 2012 | 06:11 PM
SuperSabre's Avatar
SuperSabre
F26 = F250 four wheel drive truck. C = 292 cubic inch V8 2 bbl engine. K = built in Kansas City. 470554 = built in October 1963 as a 1964 model. 120 = your wheelbase in inches. A = Raven Black exterior color. F260 = 6800 GVW 3/4 ton truck. E81 = Custom Cab Red crush vinyl and red check stripe woven plastic upholstery. F = 4 speed manual transmission. B4 = Dana 60 limited slip differential. My '66 workshop manual lists that as a 4.10 ratio. Another reference book I have says in '64 it was a 4.56 - so probably the latter, but possibly the former. You left out the last line of the door tag which would give you the GVW, which we already know is 6800 lbs, the NET hp and the rpms where it is developed, and the DSO information. Hope this helps.
Old Feb 25, 2012 | 06:15 PM
66crawler's Avatar
66crawler
The last line is, 6800 135 3800 and I assume the last number 73 is the dso? Thanks for your help, the PO said it has 456 gears and it feels like it lol.
Old Feb 26, 2012 | 04:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
6,800 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from.
F = Borg Warner T-98 4 Speed M/T (F: 1965/93: Borg Warner T-18 4 speed M/T).
B4 = Spicer/Dana 60 Rear Axle / 4.56-1 / Limited Slip / 5,200 lb. Rear Axle Capacity (B4 = 1965/79: 4.10-1).
Old Feb 26, 2012 | 10:29 AM
66crawler's Avatar
66crawler
Thanks ND.
shortwide
Apr 16, 2012 10:41 AM
kdda191
May 25, 2011 10:14 PM
66JOMO
24
May 10, 2011 01:50 PM
shanekbms
Nov 4, 2010 06:12 AM
grandads76
Jul 9, 2010 06:06 PM
