Help with 65 Data tag please...
Old Jul 7, 2010 | 11:57 AM
grandads76's Avatar
grandads76
I hate to ask this b/c I know it's asked a million times but I can't find the info anywhere... I just got a 65 F100 to restore and need the data tag decoded...can someone please help?
F10DL692542
Reading left to right on first line:
? 115-title is scratched
Color F
Model F101
Body 281
Trans A
Axl 07
Reading left to right second line:
GVW 4200
Cert Net HP 172
RPM 4000
DSO 21
I appreciate your help!!
Old Jul 7, 2010 | 04:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F10DL692542 / 115 / F / F101 / 281 / A / 07 / 4200 / 172 / 4000 / 21
F10 = F100 2WD
D = 352 2V
L = Michigan Truck Assembly Plant.
692542 = 1965, assembled May 1965.
115" Wheelbase.
F = Arcadian Blue.
F101 = F100 2WD, 4200 lbs. GVWR
281: 2 = Medium Blue Crush Vinyl & Medium Blue Wicker Pattern Vinyl / 81 = 81A Standard Cab.
A = Ford Type 3.03 3 Speed Manual all Syncromesh Transmission.
07 = Ford 9" Rear Axle / 3.25-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
4200 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
21 = Atlanta GA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Jul 7, 2010 | 07:08 PM
grandads76's Avatar
grandads76
Where do you get this info? I searched everywhere!
Thanks!
Shane
Old Jul 7, 2010 | 08:54 PM
NumberDummy
1964/72 Ford Truck Parts Catalog, which is available on a CD from hipoparts.com for about $22.00.
Old Jul 8, 2010 | 03:44 PM
grandads76's Avatar
grandads76
I went ahead and ordered that book, thanks for that!
But would you mind decoding this one? Cant wait till book gets here lol.
1969 Ranger
F10YNF30999
WB 131
Color P
Model F100
Body L 81
Trans C
Axle 17
Second row does not have titles these are in order left to right:
05000
175
4000
24
Thanks a ton (in advance)!
Shane
Old Jul 9, 2010 | 02:36 AM
camperspecial65's Avatar
camperspecial65
F10= F100 1/2 ton truck, 2WD
Y= 360 V8, 2bbl carb
N= Norfolk Assy. plant
F30999 = April 1969 build date..April run began with F30,000..
WB 131= wheelbase in inches
Color = P= exterior color...Medium Ivy Green
Model = F100...2WD 1/2 ton truck
L81= L: Pastel Parchment Corinthian Vinyl & Lt Parchment Granada Pattern Vinyl
81= 81B= Custom Cab truck
Trans = C= Ford 3 speed manual transmission
Axle = 17= 3:25 ratio open rear end, Ford WDM-H-S, 3.3M load rating
5000= trucks max GVW in lbs
175 @ 4000= Engines cert. net H.P. at specified RPM
DSO= 24= Jacksonville...where original selling dealer ordered truck from
- cs65
Old Jul 9, 2010 | 02:44 AM
NumberDummy
1969 Ranger
F10YNF30999
WB 131
Color P
Model F100
Body L 81
Trans C
Axle 17
Not necessary, I know the sequence and could decode all this jazz whether you listed the titles or not.
05000 / 175 / 4000 / 24
F10 = F100 2WD
Y = 360 2V
N = Norfolk VA Assembly Plant.
F30999 = 1969.
131" Wheelbase.
P = Medium Ivy Green.
F100 2WD, 5,000 lbs. GVWR
L81: L = Pastel Parchment Corinthian Vinyl & Light Parchment Granada Pattern Vinyl // 81 = 81B Custom Cab-Ranger.
C = Ford Type 3.03 3 Speed Manual all Syncromesh Transmission.
17 = Ford 9" Rear Axle / 3.25-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
175 net HP @ 4,000 RPM
24 = Jacksonville FL Ford District Sales Office, where the original selling dealer ordered the truck from.
Ford confusion.
After decoding your 1965 info, I thought I'd pass the following along, so you won't be confused.
A was used in 1965 for the type 3.03 3 speed. C was used 1966/72.
07 was used in 1965 for the 9's 3.25-1 ratio. 17 was used 1966/72.
Edit: Hmmm, I see that Squire Don (cs65) beat me to it by 8 minutes.
Old Jul 9, 2010 | 10:23 AM
grandads76's Avatar
grandads76
Thanks guys!!
Someone, at some point, had it repainted red. It must have been a pro job when it was done because the interior, jams, etc are all red now. I saw it chipping in places with some green under it so i figured the red wasnt original. Is there any more desirability on the truck for it being a Ranger Custom Cab?
Thanks!
Old Jul 9, 2010 | 03:13 PM
camperspecial65
LOL...yeah...how'd I do with the 69 ??? I couldnt find the build date info on the CD...had to break out one of the 6" thick books ...
Another question Bill, On the rear ends...or front axles, etc...when they say its a 3.3M or 3.5M rating...is that always gonna be a 3300 or 3500 # rating using those two as an example ???
On the 3 speed trans...Ive never seen it said the trans is a 3:03 All Syncro Trans...it usually just says Ford 3 speed with the Ford code similar to what I posted on the rear end with this particular decode...
Its nice getting something different to decode once in a while :-)
- cs65
Old Jul 9, 2010 | 03:31 PM
NumberDummy
Abso-tutly
Since the Ford type 3.03 3 speed all syncro was introduced in 1963 and came as standard equipment on 1963/72 F100/250's, 1967/72 F350's, and from 1973 thru 1986 on others, I add the info when I decode the TRANS code.
1968/72 F100's: There were TWO different 9" rear axles. One had a weight capacity of 3300 lbs, t'other 3600 lbs.
Even though classified as a 9 inch, the 3600 pounder has a 9 3/8" ring gear, only 5 internal parts are the same as the 3300 pounder.
Dana 44 front driving axles: There were three weight capacities offered 1959/72: 3M (3,000 lbs.), 3.3M (3,300 lbs), 3.5M (3.500 lbs).
Old Jul 9, 2010 | 04:19 PM
camperspecial65
Thanks Bill...were the 3 speeds all column shift as far as the F100-350 trucks go...I would ask that about the cars too, but the Mustangs Im pretty certain had floor shift for the 3 speed.
- cs65
Old Jul 9, 2010 | 06:06 PM
NumberDummy
How many 1965/2010 Mustang's have a column shifted manual or auto trans? None.
1952 was the last year that F Series trucks had a floor mounted 3 speed shift lever, used with the H/D 3 speed manual trans only on F1/F2/F3's.
cstempert
Feb 24, 2015 10:52 AM
Schaffner
Feb 2, 2015 08:45 PM
flypfi
23
Oct 21, 2014 03:36 PM
floorfact1
Sep 7, 2014 09:33 PM
