Injection Pump question
Old Feb 25, 2012 | 04:00 PM
Blitzcraig's Avatar
Blitzcraig
Will an IP off of a 1992 7.3 fit on a 1993 7.3 turbo?
Old Feb 25, 2012 | 05:59 PM
84-6.9L's Avatar
84-6.9L
Yep just needs to be adjusted a bit but will work just fine in stock form, although the turbo will benefit from turning the fuel up a bit, but if you don't have a pyro leave er be.
Old Feb 25, 2012 | 06:08 PM
rhkcommander959's Avatar
rhkcommander959
yes it will
Old Feb 25, 2012 | 06:50 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
yes.but the specific turbo calibrated pump would be ideal for your '93 turbo engine.
DB2831-5069/DB2831-5070
as i understand,its not just about fuel rate,but the internal timing of the pump is set for better boost performance.
if you found a good used or rebuilt one for the right price,hey why not.but if your looking for the correct replacement for max performance,then look for the turbo ip.
https://www.ford-trucks.com/forums/1...ning-info.html
Old Feb 25, 2012 | 08:58 PM
Blitzcraig's Avatar
Blitzcraig
Yes its at a junkyard for $50. I thought it wouldn't hurt to try it.
Old Feb 25, 2012 | 09:03 PM
Blitzcraig's Avatar
Blitzcraig
I found it in a junkyard for $50. I thought for that price it wouldn't hurt to try it. Should I get the injectors that are with it too?
Old Feb 25, 2012 | 10:25 PM
FORDF250HDXLT
ah ok.well pretty hard to beat that.it's hard to say without testing them,but if your truck is running real rough and they'd pretty much give the injectors to you or for just a few bucks,then you could try 'em.anything is better than completely shot ones.
Old Feb 25, 2012 | 11:16 PM
Blitzcraig's Avatar
Blitzcraig
Idk about timing this thing when I get it installed. Will it run good enough to get it to a mechanic for pulse timing? Is there a wrong way to install it that could damage something trying to start it? Any good links to get it back running enough to get it to the mechanic?
Old Feb 26, 2012 | 12:18 AM
Blitzcraig's Avatar
Blitzcraig
Also, what tools do I need to take with me to the junkyard to remove the IP? It's a take it off yourself kind of yard.
Old Feb 26, 2012 | 11:20 AM
FORDF250HDXLT
click the link in my signature below that's titled: 100k Interval; IDI Tuneup.
direct link;
Old Feb 26, 2012 | 05:48 PM
Blitzcraig's Avatar
Blitzcraig
I got the pump and all the injector lines but one for $34. Someone got the other line already. I thought it would be better not to break those lines loose at the pump if I didn't have to. Looks harder to put back on than it was to take off.
Old Feb 26, 2012 | 06:47 PM
FORDF250HDXLT
nice deal.back on is actually easier than taking out.you'll do just fine.
Old Feb 27, 2012 | 11:53 AM
jaluhn's Avatar
jaluhn
Yes, the OEM turbo pump has slightly different internal calibration for timing curves and such in addition to the screw being turned up, however since a stock NA pump works fine turned up with aftermarket turbo setups I see no reason you need a OE turbo pump.
Tool for pump R&R:
5/8 wrench (injection lines)
9/16 socket wrench (oil filler or cover plate)
5/16" or 8 mm 12 point socket (injection pump gear bolts. Must be a 12 point in good condition)
11/16 wrench (filter to IP line)
1/2 socket (throttle cable to intake bracket)
small flat screwdriver (removing throttle cable bell ends from ip lever)
9/16 custom wrench* (injection pump nuts)
*There's a special wrench that is speced for the injection pump nuts, it's a open end that's bent in about a 1/4 circle. I made one by bending the open end of a combo wrench about 45* to the side and grinding down the box end a bit to get it onto the nut. If you remove the thermostat housing you can get the lower 2 nuts off with a regular wrench but it's a PIA. You could also pull the 4 3/8" bolts the hold the injection pump housing to the block and just pull the entire unit. Can't do this for installation though, so eventually you do need to special wrench.
F-250 WARHORSE
Oct 7, 2016 09:41 AM
Realslowww
13
May 29, 2015 11:51 PM
dsbyrd918
Aug 6, 2014 09:17 PM
1989f250IDI
21
May 15, 2013 10:13 PM
Dave7.3
Nov 29, 2007 09:54 PM
