Sponsored by: Real Truck
erg... brakes
Old Feb 25, 2012 | 06:22 PM
deck60's Avatar
deck60
brakes can be a pia this is how i find problems
get some brake line caps take all the lines off and cap them. See if your problem goes away, then do one wheel at a time. until you find the where the problem is at
you can get the plugs and check master cylinder also
if you don't have any fluid leaking on the ground then it is an internal leak
my bet is the master cylinder is leaking by
the calipers cant have a internal leak it is impossible
so that leaves 2 things your master cylinder or abs control module
Old Feb 25, 2012 | 06:25 PM
deck60's Avatar
deck60
you can get a good used abs assembly from a salvage yard
car-part.com
Old Feb 25, 2012 | 06:32 PM
countryboy73703's Avatar
countryboy73703
The probes are the same.... I thought it was my cylinder but then I realized my front right stuck so I replaced the front calipers. Then the cylinder and the booster at the same time... The only think to my knowledge I havent replaced are the rear calipers and the module thing under the hood...
barkfarm
Nov 24, 2015 06:39 PM
natew
Oct 31, 2013 02:00 AM
1955effie
1983 - 2012 Ranger & B-Series
Jun 30, 2009 02:56 PM
debby1254
1997 - 2003 F150
Mar 26, 2007 02:42 AM
garndog
Jan 12, 2005 06:51 PM
