Front lift blocks
Front lift blocks
I have a 66 F100 4x4 and I fabricated 2" lift blocks and installed them using grade 8 bolts. I want my truck to be safe so I have researched front lift blocks and the only information I can find refers to front lift blocks placed between the spring perch and the springs and these are NOT recommended because they can come loose. because mine have two bolts each running through them, there is no way for them to become dislodged. I have already purchased and installed new springs but I needed to lift it even higher in order to level it out. I am no engineer so please let me know if this is unsafe.
I would definitely ditch the blocks and go with a longer spring. Adding blocks to the front end adds more leverage to the front axle under braking and is not safe. The are a lot of companies out there that make taller springs for this application. As posted above, you'll need to drop the track bar (or get an adjustable one which can be made longer), the radius arm mounting points, and use a drop pitman arm also. Hopefully you used the 7 degree offset C-bushings. Is this a factory '66 4X?
"C" bushing? Not sure what these are, but if they are what I think they are, I saw a lifted '64 GTO flip upside down when one side broke. Car just basically collapsed on that side when it broke and it just flipped completely over - top down.
2Hick, I think you have taken a bad idea and tried to improve it safety-wise, but it is still basically a bad idea.
Yikes!
Jhooch, yes it is a factory 4X4. I did install an adjustable track bar and a drop pitman arm but the kit did not come with brackets to lower the radius arms. I don't remember what the offset was for the C bushings but it wasn't 7 degrees. My build was interupted when the garage burned down. I will look into longer springs and radius arm brackets.
Thanks to everyone for the input.
motorhead66
08-31-2009 10:02 AM
TrueBlueV10
1999 to 2016 Super Duty
08-05-2003 07:39 AM
