4R55E
Old Feb 24, 2012 | 03:14 PM
dybeepvw's Avatar
dybeepvw
4R55E
Can I use Mercon V in this transmission on my 96' Explorer 4.0L 4wd auto, or am I suppose to use the Mercon/Dexron fluid. Thanks
Old Feb 25, 2012 | 01:48 AM
KhanTyranitar's Avatar
KhanTyranitar
It is recommended by Ford that you upgrade to Mercon V. It is a better fluid designed to be used in place of Mercon ATF. It has better friction modifiers, more stability, and better lubrisocity, but is 100% compatible.
Old Feb 25, 2012 | 09:32 AM
dybeepvw's Avatar
dybeepvw
Thanks, Khan Tyranitar, I will go with the Mercon V. You gave me some good info in the past so thanks again.
Old Feb 26, 2012 | 09:42 AM
steve(ill)'s Avatar
steve(ill)
as Khan said, it is an upgrade. Some stores dont carry the old Mercon.
Old Feb 26, 2012 | 09:59 AM
dybeepvw's Avatar
dybeepvw
10-4 on that steve; can you put the mercon V in the transfer case and power steering.
EMC V10 X
Jan 21, 2011 09:59 AM
miichael
Mar 10, 2006 04:49 AM
euforia51
May 8, 2003 02:11 PM
jeff44ranger
Oil & Lubrication
Feb 5, 2003 01:49 PM
