sway bar
Old Jan 30, 2006 | 04:48 PM
screwloose2's Avatar
screwloose2
sway bar
I searched the sight for sway bars (front) doesnt seem like anyone is recomending any particular manufacturer . I want to put a sway bar in my 49 f1 (front) it has been lowered by removing springs other than that its stock . Any recomendations ????? also should I do the rear ????
Old Jan 30, 2006 | 06:53 PM
AXracer's Avatar
AXracer
With our trucks, a front is most important, but a rear with a front is even better.
If you want a bolt on bar, then you're pretty limited to what's offered which is probably one bar. If you don't mind some fabrication you can have a custom bar made to match your springs and front end weight for not much difference in price. I prefer a frame mounted bar rather than the axle mounted ones.
