2001 headlight removal
Old Feb 22, 2012 | 07:22 PM
STROKER350's Avatar
STROKER350
Unhappy 2001 headlight removal
Help! I got the clips off the headlight, but can't get the bottom one out. What's the secret?
Thanks for your help, I'm stumped.
Old Feb 22, 2012 | 07:40 PM
Tormz's Avatar
Tormz
When I pulled it on my 99 I had a buddy with a long pair of pliers hold the bottom clip and kinda spread it while I pulled on it. I would do thepassenger one first is easier to do and you will have a better idea for the dr side witch is harder to get to
Old Feb 22, 2012 | 07:48 PM
woodnthings's Avatar
woodnthings
Just turn the headlight adjuster. I use a power driver like a Manufacturing and a torx bit. IIRC turning it clockwise will adjust the bottom of the headlight out. If you turn it all the way it will disengage from the socket. You will find it easier than trying to squeeze the tabs together. You can use a socket (14 mm) to squeeze them, but it often doesn't work to easy. To put it back just engage the shaft and turn it the opposite way.
Old Feb 22, 2012 | 08:02 PM
STROKER350's Avatar
STROKER350
Thanks, I'll give it a try tomorrow!
Old Feb 22, 2012 | 11:30 PM
PaysonPSD's Avatar
PaysonPSD
See this THREAD
mtn dew brent
Dec 28, 2010 11:51 AM
live2hunt
1978 - 1996 Big Bronco
Aug 26, 2007 07:17 PM
HUNTER10
Mar 10, 2007 08:50 PM
Landyot
Feb 5, 2004 08:14 PM
Toreador_Diesel
Feb 4, 2004 01:11 PM
