Engine makes a chattering sound at idle
About a week ago I started my truck up and it had a weird chattering sound at at idle. When Im driving down the road it sounds normal except for certain RPM's the chatter comes back, although its not as loud as it is at idle. My water pump had a slight leak in it a month ago (just stoped leaking after 3 days) so Im not sure if that has something to do with it or not. Anyone have any ideas?
The last time I had a chatter at idle it was kind of a clicking or tapping sound. Pulled my valve covers and checked my injector hold-down bolts. Almost every one was loose and tightened them down. The noise went away. It may not be your problem like me, but it's a free check (all it cost me was a beer).
I don't remember the spec's, but there's plenty of posts if you search for it (I'm on a ship and my connectivity is worse than dial-up otherwise I would link it for you).
Best of luck.
Best of luck.
Not yet. I planned on doing that today.
Best of luck.
Best of luck.
Check the injector bolts and the rocker arm bolts also.
look this thread over. Post #6 has the bolt torque info.
https://www.ford-trucks.com/forums/9...lve-cover.html
First off lemme say Chris, long time brother!
I dont know if your still in florida or where you are, but I have had a similar thing happen. What my problem was is I had some ice stuck in SOMEWHERE after doing some deep snow driving, and what fixed my problem is I brought my truck into my shop and let it thaw right out.
What oil weight are you using and is it 'cold' where you are?
Its been anywhere from 15-50 degrees since this started.
Thanks for the link.
No Im back in Maryland now. I dont think it would be from ice, its been warm enough a few days where it would have melted everything
