Removing engine for oil pan
Old Feb 22, 2012 | 08:38 AM
wicat3's Avatar
wicat3
Hey guys ive asked this before but looked around and want to be 100 percent before i get into it. I have a 92 f150 4x4 5.0L that needs an oil pan. My question is do I need to pull the transmission from the motor or can i undo the motor mounts and jack up the motor and change it that way? Also does anyone have the tourqe specs for the bolts?
Old Feb 22, 2012 | 09:29 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...n-removal.html Have a read here.
Old Feb 22, 2012 | 09:38 AM
wicat3's Avatar
wicat3
Thank you very much
Old Feb 22, 2012 | 10:10 AM
Nick_lebbad's Avatar
Nick_lebbad
i know you already got an asnwer but i literally just replaced my oil pan gasket on my inline 6.. i removed the motor mounts (and replaced it..) and loosened the tranny cross member bolts and was able to jack the motor up high enough to drop the pan.. was a PITA but it worked and the shop i called said their service manual says to drop the tranny to replace the pan or gasket.. which is like 6 hours they said.. the 4x4 makes all the difference.. if it wasn't there it would be pretty easy..
Old Feb 22, 2012 | 10:51 AM
wicat3's Avatar
wicat3
Yea the 4x4 is a must have for me but makes everything so much harder. Anybody have torque specs for the bolts?
Old Feb 22, 2012 | 10:55 AM
77f-250's Avatar
77f-250
just snug them down good not to tight or you'll crush the gasket.
Old Feb 22, 2012 | 11:00 AM
wicat3's Avatar
wicat3
sounds good
Torch89891
Aug 31, 2009 10:45 PM
gota0have0boost
Jan 16, 2007 07:14 PM
oxfordgt
Nov 7, 2006 09:16 AM
Blue89F150
Aug 3, 2004 12:10 PM
scooter_1968
May 19, 2003 11:19 PM
