DIY Oil Change
Old Feb 21, 2012 | 12:47 AM
GeneLaw1's Avatar
GeneLaw1
DIY Oil Change
Gentleman,
In the next few months I will be doing my own oil change, and I had a few questions about the materials I need:
1. What type of oil is good? I've seen Rotella (sp?), and the Royal Purple. Anyone have some good recommendations?
2. I will probably stick with the 15-40 since it does not get cold here...should I go to Synthetic?
3. Where is a good place to get the filter from? i know its important to use Motorcraft but I thought I remember reading that some folks on here got the filter from some website that sells Ford parts.
Any other tips for sucess would be nice as well, Thanks!
Cheers,
Old Feb 21, 2012 | 01:42 AM
Dieselpop's Avatar
Dieselpop
Originally Posted by GeneLaw1
Gentleman,
Cheers,
1. Mobil 1 Turbo Diesel Truck 5W-40
SAE 5W-40 Full Synthetic Diesel Motor Oil
Rotella T6 5w40
2. You should use a 5w40 Syn oil your injectors will like it.
3 Oil filters Walmart MotorCraft FL-2016
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
pop
Old Feb 21, 2012 | 04:55 AM
npccpartsman's Avatar
npccpartsman
I think you'll notice a difference with the 5W40 synthetic, even in the warmer climate. You can get the filter from China Mart in Fram (CH9549) and it's the same as the Motorcraft FL2016. Just be sure to open the box and check to make sure some jackleg didn't switch and return it. If you order ALL the truck filters in "bulk" you can get a good deal from Dieselfiltersonline.com and save some shipping.
Old Feb 21, 2012 | 06:10 AM
zhilton's Avatar
zhilton
You'll also want to pick up the 32mm socket from your local ORielly's or Sears. Lisle make it and will be a 3/8" drive...you'll need it for both the oil filter & HFCM filter.
Old Feb 21, 2012 | 06:31 AM
npccpartsman
Originally Posted by zhilton
You'll also want to pick up the 36mm socket from your local ORielly's or Sears. Lisle make it and will be a 3/8" drive...you'll need it for both the oil filter & HFCM filter.
Fixed it for ya
Old Feb 21, 2012 | 07:00 AM
zhilton's Avatar
zhilton
Originally Posted by npccpartsman
Fixed it for ya
Ya' cheated...yours is allot handier than mine right now I was going from memory.
Old Feb 21, 2012 | 11:37 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
If you are going to start doing your own service work, might I suggest:
Water drain valve:
DTS Articles - HFCM Water Separator Drain Plug Upgrade
Fumoto oil drain valve:
F-111 or the F-111N The "N" has a nipple to attach a drain tube.
I went with the F-111N. For ease? No, Ford charged me $15 for a new copper washer for their drain plug. Not any more!
Old Feb 21, 2012 | 11:47 AM
GeneLaw1's Avatar
GeneLaw1
Ah, is draining the water separator part of the oil change as well? I was under impression you did this when you changed the fuel filters (which I will probably try to do myself as well when time comes)
Old Feb 21, 2012 | 11:53 AM
amdriven2liv
Yes, you should drain it at least that often. One, it helps you see if your fuel supplier is good. Two, keeping the water out of there, reduces the amount of rust that can take place in there.
Old Feb 21, 2012 | 11:55 AM
amdriven2liv
Oh, and the stock plug can strip. Might as well eliminate that issue now. Also helps the draining process before your fuel filter changes. Less diesel in your face!
Old Feb 21, 2012 | 12:09 PM
GeneLaw1's Avatar
GeneLaw1
What kind of differences?
Old Feb 21, 2012 | 12:38 PM
Ian123's Avatar
Ian123
FYI you can also get the 36mm socket from Lowes, they sell one for like 8 bucks
Old Feb 21, 2012 | 01:49 PM
built tough's Avatar
built tough
everyone i know with a 6.0l either runs 5-40 or 10-30 was always told the 6.0l didnt like the 15-40 so i would recomend one of them 2 as far as oil filter I use fram and the 10-30 motocraft oil and these trucks are the easiest vehicle i have ever changed the oil on hands down
Old Feb 21, 2012 | 02:03 PM
GeneLaw1's Avatar
GeneLaw1
Seems straightforward enough, only thing you need to get under the vehicle for is to drain the oil right? The filter is on the top?
Old Feb 21, 2012 | 02:04 PM
GeneLaw1's Avatar
GeneLaw1
I am always for less diesel in the face. It seems from the article you posted this is a solid investment, since I definitely plan to start doing my own services. The money saved goes a long way....i.e., they charged my $150 to change my filters. Seems I can do it for about $50 in parts, that $100 can go towards a tank of gas
