Popping
Old Feb 20, 2012 | 09:07 PM
keithm1961's Avatar
keithm1961
Popping
I've got a 1984 302 out of an E-150 with a 2bbl carb. I've eliminated the AIR system and removed the EGR valve. I installed it in a 1990 ranger. engine starts right up but has a steady popping in the carb. I've checked timing, air leaks, firing order. idle is nice and smooth but if accelerating back fire thru carb. carb has been rebuilt, could the power valve being bad cause this?
thanks
Keith
Old Feb 26, 2012 | 12:02 PM
LxMan1's Avatar
LxMan1
Timing off or crossed plug wires could be the cause. Also, a non working accelerator pump in the carb could cause a lean condition and popping thru the carb. Look down the carb with the engine off and make sure it is squirting gas when you open the throttle.
Old Feb 27, 2012 | 07:03 PM
keithm1961's Avatar
keithm1961
found it
well, the update is the number 7 exhaust valve push rod was bent.
I replaced all the pushrods and viola runs great. I appreciate all the good ideas
Keith
Robby8279
Nov 16, 2011 06:20 PM
baverwolf
20
May 7, 2010 09:59 AM
FordF100man
16
Jun 19, 2007 09:47 PM
greybullit
Aug 16, 2005 12:56 PM
popman
Apr 21, 2003 03:09 PM
