Carb choice?
Old Aug 15, 2005 | 04:56 PM
greybullit's Avatar
greybullit
Carb choice?
I have a stock 360 and I just replaced the intake and carb. It used to be a 2bbl carb. Now its a 4bbl Holley 650. It seems to idle pretty good but sometimes sputters a little bit when starting, did I go to big with the carb or could it be something different? Could it just be putting too much gas in to the motor? The timing is all good so I know its not that. Any ideas? Thanks
Old Aug 15, 2005 | 06:20 PM
ford390gashog's Avatar
ford390gashog
have you fine tuned it? hook up a vacuum gauge a tune it.
Old Aug 16, 2005 | 12:55 AM
Mil1ion's Avatar
Mil1ion
Most carb problems are cause by the power valve or a leaking butterfly rod.
Do the test with a can of carb cleaner by spraying it all around the carb but in the air horn, listening for a engine running change.
Old Aug 16, 2005 | 02:44 AM
greybullit's Avatar
greybullit
I'll try that for sure.
Old Aug 16, 2005 | 12:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can find carb tuning help in the carb forum.
