Sponsored by: Real Truck
Crew cab door adj
Old Feb 20, 2012 | 09:04 AM
trekbasso's Avatar
trekbasso
Crew cab door adj
Hi all,
Any thoughts on how to tighten up the door strikers on a crew cab?
They rattle a lot, and do not look adj.
Is this something the weatherstrip mod will help?
01 F250.
Thanks.
Tom.
Old Feb 20, 2012 | 01:17 PM
SteveH-CO's Avatar
SteveH-CO
If the door does not sit flush while latched, move the striker closer to the middle of the truck. The weatherstrip mod may help, but if the latch piece is worn badly, probably not. Note that most door striker bolts are VERY tight - use the correct bit and approach to loosen them, lest you strip out the head.
Old Feb 21, 2012 | 09:08 PM
trekbasso's Avatar
trekbasso
Thanks. I thought I tried to adj last year and the striker didn't want to move. I might mess with it tomorrow. Latches could be worn also. Doors are fitting good as far as gaps and flushness.
mizzitch
Jan 25, 2013 02:32 PM
brentleedragon
Oct 24, 2008 03:30 PM
st3ib
Mar 8, 2007 03:49 PM
notsoswwuyd
Jan 23, 2005 10:15 PM
scr8pin_f100
Jun 29, 2002 06:36 PM
