Twisted and warped cab.
Old Jun 28, 2002 | 10:49 PM
scr8pin_f100's Avatar
scr8pin_f100
Scr8pin_f100
Hello, I have yet another question to try to stump someone with. I have a 1955 F-100 and I've finally got the cab on the new frame. However, it is in horrible condition. I will have to replace all 4 corners, rockers, and patch the rest of the holy hunk of metal!
Because of the terrible state of the cab, the cab twisted a little while moving it. This seems to have effected the drivers side door. When the door is closed, I have a 1/4 -1/2" gap between the rear of the door and the striker. I think I can fix this problem by "squeezing" or making the cab square again. I need to know the measurements of the door opening both inside cowl to cowl and where the rubber from the door meets the cab.
Any help would be appriecieated!!
Old Jun 29, 2002 | 02:27 PM
Franklin2's Avatar
Franklin2
All cabs are different. The factory adjusted and shimmed so the opening would fit the door. You will have to use the door you have as a reference. You can shim the cab and the door hinge mounts too.
Old Jun 29, 2002 | 06:36 PM
viking's Avatar
viking
Cougar54
Oct 18, 2015 09:26 PM
aelmo
15
Aug 5, 2013 07:01 PM
N69MF
Paint & Bodywork
Oct 31, 2004 12:29 AM
Fat Fendered Ford
Dec 22, 2002 01:02 PM
