6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
When is more intake air required?
Old Feb 20, 2012 | 07:45 AM
LaredoF350's Avatar
LaredoF350
Are there any approximate tuner power levels where the stock intake becomes restrictive?
Can some be gained with a hi-flow filter in the stock canister, and if so, what power level will this be compatible with?
What power level just flat out requires a CAI?
Old Feb 20, 2012 | 12:46 PM
UGA33's Avatar
UGA33
Running Spartan tuning, the 210hp file is where you need a CAI
Old Feb 20, 2012 | 01:33 PM
SANDDEMON08's Avatar
SANDDEMON08
The stock filter will support up to 150 HP gain, after 200 HP gain the CAI is required otherwise you constantly suck the filter minder down. I played with the high flow filters and found they were a waste of time couldn't find one that could flow enough so i went to a CAI. FYI, I have tried several CAI S&B, AFE stage II with the cold air tube and the volant. Out of all of them the volant performed the best for me. The volant gave me the coolest intake air temp before and after charging.
Old Feb 20, 2012 | 07:32 PM
LJC's Avatar
LJC
I am using a green filter drop in ( in the stock box) and running Spadtan 210 or 250 without issues.
Old Feb 21, 2012 | 09:30 AM
StanleyZ's Avatar
StanleyZ
I have only a 35HP tune with a stock air filter. It keeps sucking mine down to about halfway on the filter minder. Tried a new stock filter, did the same thing. Doesn't that mean I need more air flow?
Old Feb 21, 2012 | 11:05 AM
R-T0r21on's Avatar
R-T0r21on
I agree Stanley. I had mine getting sucked up when my truck was all stock. It's an early Job 1, if that makes any difference. Maybe the filter minders are different/more sensitive on early trucks? Once I went with the CAI, I never had an issue with any power level.
Old Feb 21, 2012 | 12:33 PM
UGA33's Avatar
UGA33
If its sucking the filter minder halfway down, its time for a CAI
Old Feb 21, 2012 | 02:49 PM
LJC's Avatar
LJC
Yes, that is very strange! Adding just 35 HP should be done easy with the stock filter... I guess the stock filte is not dirty, right?
Old Feb 21, 2012 | 04:18 PM
StanleyZ's Avatar
StanleyZ
Well, I considered that possibility and went and paid the ransom Ford gets for a brand new filter. It does the same thing. Although I am finding that I have to stand on it pretty hard to get it to do it.
Old Feb 21, 2012 | 07:12 PM
LJC's Avatar
LJC
You can also use a drop-in filter in the stock box (it is already a CAI box, right?).
AFE, GREEN filter are examples
Old Feb 21, 2012 | 08:04 PM
StanleyZ's Avatar
StanleyZ
The box is stock, I guess we could call it a Cold Air induction box. It has a drop in filter. So, I could just order the filter. Are we sure it filters enough to keep me from injesting any unwanted "stuff" and sanding my turbo?
Old Feb 21, 2012 | 08:39 PM
LJC's Avatar
LJC
I think that the 2 I mentioned are doing a fantastic job. I have my filter now for 30k
hilio
Feb 22, 2012 04:00 PM
bebeard
Dec 20, 2011 05:48 PM
xluckyxbulletsx
Aug 13, 2009 08:22 PM
Norvous
1997 - 2003 F150
Apr 14, 2007 12:58 PM
syc25ss
Aug 12, 2006 08:53 PM
