I did it finally....got the oil cooler off, buffed both the block with a grinder that had a really stiff wire wheel...and the oil cooler....put some high tack on and threw the gasket on....bolted it all together, filled it with new coolant...and called it good....decided to do a startup....that had NO LEAKS FINALLY!! Here is the video, still havent worked out the GP wiring issue, gonna replicate the Banks Bracket with help from Eaton9999. He is gonna send me his so I can replicate it.
Nice. Once you get that exhaust all sealed up, you should get more boost. Keep up the good work!
I don't know for sure but I thought I saw a tranny jack at Northern Tool for a hundred and a half to two hundred. I won't lie, it's gonna be a b!+ch to get it back in just seeing how hard it was to drop the spare I have. But that was an E4OD.
