Sponsored by: Auxito
led underdash lighting, 2 triggers?
Old Feb 19, 2012 | 04:05 PM
kbsupercrew's Avatar
kbsupercrew
I have a 2000 f150 and I want to install underdash led lighting and led lighting under the back bench seat, normally it says to wire it into a 12v supply with a toggle switch, or use cigarette lighter adapter.
I want to wire them into the courtesy lighting circuit and the headlight circuit using blocking diodes(rectifier diodes) on the positive side of the wiring and run two triggers, to have them turn on when you open the door and off when you close it, and turn on and off with the headlights .
Has anyone tried this?
Old Feb 19, 2012 | 05:01 PM
Longdistancetrucker's Avatar
Longdistancetrucker
I have done a similar setup with my POV responder lights, I don't see any problem with it.....
Old Feb 21, 2012 | 05:03 PM
Longdistancetrucker
Exclamation
I have posted photos under my account....
Dominating
Sep 17, 2012 05:17 PM
WA_PSD
Feb 2, 2012 10:09 PM
Ozzy57
Electrical Systems/Wiring
Jan 23, 2006 08:38 AM
F15090300
Jan 10, 2005 07:43 PM
tlb
Aug 18, 2004 07:19 AM
