It a digital gauge Shows 4 gauges at 1 time. Will monitor anything from water and oil temps, fan speed, turbo vgt's, boost, injector miss fires, monitors icp sensor and hpop just to name a few, you can preset 24 thing to monitor at a push of a button A must have for 6.0 owners
Does anyone know if it will work along side the edge juice platinum that plugs into the pcm. I know ae and ids are unable to communicate with the pcm with the edge hooked up. I will take it if anyone is sure it will work.
From what I've heard, there is a splurged on amazon but its a hit and miss whether 2 different brand of devices are split into the obd2 port. It does work for some and doesn't work for others, but have never tried it
My obd port is open. The edge plugs into the pcm directly (under the hood). Not sure if you got that from my post. Maybe someone on here has tried it.
