Sponsored by: Real Truck
Boost Gauge issues.. MAP sensor?
Old Jan 30, 2013 | 09:04 PM
Chris Thomas's Avatar
Chris Thomas
I just got my truck running again. Did Head studs and had to replace the High pressure oil pump.
Now that it's running It is doing great. I hooked up my Edge Juice with Attitude for the gauges, and noticed that there was no boost on the gauge. At first I thought it was a turbo issue, but after continuously driving today it has plenty of power and no more or less lag that it used to.
I checked under the hood and found the gray plastic tube unplugged, but nothing changed on the engine or gauge when I plugged it in. The rubber hose from the top of the manifold up the the wiring that I think is the MAP sensor appears to be all secured with no cracks.
The truck is a 2004 6.0L automatic with 216k.
Is my attitude just shot? I think I'm gonna go with some new gauges anyhow, but just thought I'd get some insight in the meantime. Like I said, it seems to be running fine, just nothing registering on the gauge.
Old Jan 31, 2013 | 07:26 AM
senix's Avatar
senix
you should post this down in the 6.0 forum for the best advice.
If your turbo is spooling then I'd say you have a guage issue.
McBusiness11
Mar 31, 2017 03:57 PM
Walleye Hunter
76
May 30, 2014 09:30 PM
94 smokin stroker
Sep 24, 2010 04:34 PM
Brown Falcon
Aug 4, 2010 06:15 PM
mudfox26
Jan 29, 2005 08:10 AM
