Sponsored by: Auxito
Good deal?
Old Feb 18, 2012 | 09:34 PM
Louie3's Avatar
Louie3
Good deal?
Yes or no? What should I look out for?
http://mcallen.en.craigslist.org/pts/2858920088.html
Old Feb 19, 2012 | 01:32 AM
Longdistancetrucker's Avatar
Longdistancetrucker
Price-wise it is a fair deal.
I'd want to make sure that the supporting parts are included (shouldn't be a problem) and obviously make sure that there is no free spinning, or side to side play. . The housing should be free of cracks, and make sure that the mounting/pulley threads are not stripped or damaged in any way. Check the impeller edges and make sure that they are not "messed up" from any internal dirt or other debris.
If you are able / allowed check the drive gears by removing the oil (or grease, not sure) injector, drain the plug and look at the gears thoroughly (you may want to bring a flashlight) If there are any metal shavings or broken teeth, be aware that is cause for concern.
In addition you may want to check the oil (Grease?) injector. There is normally a screen in the inside, just be sure it is reasonably clean and not clogged.
Good luck, and keep us posted,
John
Old Feb 19, 2012 | 06:50 AM
92nite351's Avatar
92nite351
i want one.... lol. might look into this next winter...
Old Feb 19, 2012 | 12:01 PM
phil6608's Avatar
phil6608
Fare deal(nothing special) if it dosed need rebuilt and the miles are not to high.
That's about the going rate for them in good shape!
You do know you will need to spend around $2500. more for the hole set up don't you?
Old Feb 19, 2012 | 12:17 PM
Louie3's Avatar
Louie3
Originally Posted by Longdistancetrucker
Price-wise it is a good deal.
John
Thanks I wrote down a list of all the things to check for. I know I can wiggle him to a lower price
Old Feb 19, 2012 | 12:18 PM
Louie3's Avatar
Louie3
I am aware that I need a lot more parts for this but it's a long term project. Ill be buying parts when ever I see them at a good price
lupuseven
Jan 1, 2013 11:19 PM
77f2504by4
Garage & Workshop
15
Aug 2, 2008 09:06 PM
dmueller71
May 1, 2008 08:03 AM
Redmanbob
19
Apr 15, 2008 07:10 PM
OffRoadF-150
Offroad & 4x4
Aug 24, 2005 11:03 PM
