Bad cat on 2001 kr? not sure
whats up guys i have a 2001 king ranch and its been making a really weird rattle lately but only when i was idleing so i decided to look under the truck while it was running and i started poking around and i realized it was the cat that was rattling, i dont know too much about but my buddy said a rattling cat means its on its way out...what do you guys think? and if it is on its way out should i replace the pair or all 4? and what brand do you guys reccommend. any advice helps. thanks
Truck heat shields are better attached than a lot of cars would be. Just use a rubber mallet and thump all the cats. A metallic clang is usually a heat shield problem, either loose or bent up against the cat. If the cat is shot internally, you should get a noise like lead shot rattling in a tin can. Note that the cat can also just get ruined from oil contamination or super heating from a prolonged misfire, but you should have gotten CEL indication of those problems.
Dave
Dave
c00nhunterjoe
22
08-09-2007 02:11 PM
