Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
vin decoding
Old Feb 18, 2012 | 04:37 PM
n800ford's Avatar
n800ford
vin decoding
Hi, I'm new here. I'm working on a N800 Ford Truck. I need to know the exact year built, engine size and carburetor model. The Vin is: N80FVL35450
I think its a 361, but cant find what year. Any help is appreciated. Thx.
Old Feb 18, 2012 | 08:05 PM
mikeo0o0o0's Avatar
mikeo0o0o0
N80=LN800 (gas)
F= 391-4V
V=Kentucky Truck Plant
L35450=Consecutive s/n. Not sure which year. My books only cover 1973 which goes from Q10,000 (Aug. 72) to S39,999 (July 73)
BTW, Welcome to FTE.
Old Feb 18, 2012 | 08:55 PM
USArmyTaterness's Avatar
USArmyTaterness
handy lil pic for you to keep on file too makes looking these up fast
Old Feb 19, 2012 | 08:02 AM
n800ford's Avatar
n800ford
thanks
Thanks for the help. This old truck has been sitting for 15 years. I cleaned the fuel lines and tank and installed an electric fuel pump and it fired right up. The it won't throttle up though. I'm checking the spark plugs and firing order and looking at the carb. I"m not too good at carbs. Any help where to start on the carb? Also, should I remove the old mechanical fuel pump or just leave it in? Thanks.
Old Feb 19, 2012 | 08:04 AM
n800ford's Avatar
n800ford
Also, what does the 4V mean? Is it the carb 4 barrel? Any way to know exactly what carburetor it has?
Old Feb 19, 2012 | 08:34 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, 4V means four barrel. The "V" stands for venturi, the technical term for barrel. I'm not sure which carbs. Ford used on the heavy trucks but my guess would be either Motorcraft/Autolite or, more likely, Holley.
If it's a Motorcraft/Autolite it will probably be a 4150 series. There should be a small metal tag attached to the front part of the carb with a number stamped on it. It should look something similar to D7TF-AA. If it's a Holley there should be a number stamped on the airhorn that starts with the word "list". This will ID which Holley it is.
Old Feb 19, 2012 | 04:35 PM
n800ford's Avatar
n800ford
The carb is a Holley with list # 4136-1 which I could not find any reference to on any website. Is this a common carb and can I find parts easily?
What's the best place to start on a carb that's been sitting for 15 years? I got this truck running, but must manually push the accelerator pump on the side of the carb to keep it running. It won't accelerate using the foot pedal or stay idling. Thanks for the help
Old Feb 19, 2012 | 05:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mikeo0o0o0
N80 = LN800 (gas)
F = 391 4V FT engine.
V = Kentucky Truck Plant
L35450 = 1971.
1971 C/CT/L/LN/LNT/LT/LTS500/1000: Numerical Sequence of Assembly: J90,000-M30,001.
n800ford: The carb ID tag is triangular, attaches to the airhorn, has a number similar to this marked on it: DOHF-E / But many of these tags are missing by now.
1970/72 LN800 & etc 391 4V
Tag: DOHF-E = D2HZ-9510-K (replaced DOHZ-9510-E) .. Holley 4V Carburetor (Motorcraft CA-876-A).
D8PZ-9A586-BB (replaced: D8PZ-9A586-BA, D5PZ-9A586-HA, D5PZ-9A586-H & C9HZ-9A586-B) .. 4V Holley Carburetor Tune Up Kit (No Motorcraft part number) / Obsolete
No Ford Dealer or obsolete parts vendor has: D8PZ-9A586-BB, D8PZ-9A586-BA or C9HZ-9A586-B.
D5PZ-9A586-HA =
BELL-MCCALL MOTOR CO. in Hamilton MT has 1 = 406-363-2011.
MANDERBACH FORD in Temple PA has 1 = 610-929-3683.
ANTIQUE AUTO SUPPLY in Arlington TX has 1 = 817-275-2381.
KINSEL L/M in Beaumont TX has 1 = 800-816-2894.
PARTS INTERNATIONAL in Farmers Branch TX has 2 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
D5PZ-9A586-H =
JST AUTOMOTIVE in Lebanon TN has 1 = 606-787-5293.
GREEN SALES CO. has 5.
You do not have an N800, because its last year was 1969. Is a completly different body, has a snub nose with a cab similar to 1961/66 F100/1100's.
1963/69 N/NT's look the same. 1970 and later L/LN's and etc are a totally different animal.
Old Feb 20, 2012 | 03:31 PM
LxMan1's Avatar
LxMan1
Moved to correct forum.
Sounds like a carb with a built in governor.
If you remove the mechanical pump, you will need a block-off plate to keep oil from leaking out of the hole. Depending on the mounting pattern, they are usually available from most auto parts stores in the Mr.Gasket area.
Gary38532
Dec 3, 2017 08:24 PM
rcwood
Apr 19, 2012 07:42 AM
F250 Truck Monkey
Jun 11, 2010 09:46 PM
Tyronesdude
Aug 4, 2009 04:47 PM
thosfsull
Sep 22, 2008 07:05 AM
