6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Small Coolant Leak Help
Old Feb 18, 2012 | 03:42 PM
redlinecoatings's Avatar
redlinecoatings
Was under the truck today and noticed a very small drip of coolant coming from the large coolant hose right at the connection under the fan. Also noticed there was some on the loom covered hose or wire above attached to the fan that runs up the drivers side fender. Is the loom covering a coolant hose or is it covering a wiring harness? Can someone help me out with this so I know what to replace.
Old Feb 18, 2012 | 04:19 PM
senix's Avatar
senix
Shine a flashlight on the upper hose where it goes into the thermostat housing...any white splatter there? I suspect that is where the leak is.
Old Feb 18, 2012 | 04:22 PM
redlinecoatings
I'll check that out. I've read that the connection under the fan is a bad spot for leaks.
Old Feb 18, 2012 | 04:40 PM
senix's Avatar
senix
Only way to tell is gonna be a wipe and see. Or a Confirmation of a leak elsewhere.
Here is what my upper hose looked like after it was taken off.
Old Feb 18, 2012 | 04:50 PM
redlinecoatings
Checked the tstat quickly and couldn't see anything. It's too far back for where the leak is underneath. It's right below the fan on the large hose.
Old Feb 18, 2012 | 05:04 PM
senix's Avatar
senix
Sounds like you have narrowed it down to that hose.
Old Feb 18, 2012 | 05:20 PM
redlinecoatings
Ya I'm pretty sure it's that one. Just wondering if the hose or wires above it covered in loom is in fact just wiring or is it another coolant hose?
bizzelj
Dec 13, 2015 09:09 PM
jwylie2125
Nov 26, 2012 04:53 PM
cfietze
Jan 27, 2012 12:52 AM
Acftmaintainer
Jul 9, 2011 12:27 PM
first truck
Jul 29, 2009 09:02 AM
