Coolant leak
Old Dec 11, 2015 | 12:33 PM
bizzelj's Avatar
bizzelj
Coolant leak
Got a good bit of coolant coming down from drivers side around the hose and off of the gearbox bout to get out there and start tracking it down.
Old Dec 11, 2015 | 03:37 PM
brandonrr's Avatar
brandonrr
My truck is currently in the shop right now for a coolant leak on the drivers side. It ended up being that hose under the degas bottle where that plastic fitting is where the hoses join up.
Mine only leaks where the is pressure in the system, so i had to get the truck up to temp before it'd start leaking. I went through about a gallon every 2 hours in run time, so it was a pretty decent leak.
Look there and also on the underside of the degas bottle. There could be small cracks.
Old Dec 11, 2015 | 03:50 PM
WatsonR's Avatar
WatsonR
Drivers side of the water pump housing. 1" hose and possibly a bad clamp. Where mine was.
Old Dec 12, 2015 | 09:24 AM
bizzelj's Avatar
bizzelj
Well I got everything off except for the ram intake and tube and can't see it. Didn't really want to take that off but looks like I'm going to have to
Old Dec 12, 2015 | 09:42 AM
navistarnut's Avatar
navistarnut
Coolant leaks can kill your FICM in short order so you will be glad you found it.
Old Dec 12, 2015 | 09:44 AM
bizzelj's Avatar
bizzelj
It shorts out the electrical system? I'm trying to pull the car tube now giving me some trouble got the clamps loose. Do I just yank on it a good bit?
Old Dec 12, 2015 | 09:47 AM
navistarnut
A leak can end up hitting the FICM and shorting it out if it gets enough coolant on it, it will leak inside.
CAC boots can be a bear sometimes, try to pry the lips up and rotate the tube a little bit.
Old Dec 12, 2015 | 10:02 AM
bizzelj's Avatar
bizzelj
Got it off seems to be the actual radiator hose as its got white stuff all over and a part is rubbed pretty bad the leak is coming from down low around the water pump so maybe it's that
Old Dec 12, 2015 | 10:15 AM
bizzelj's Avatar
bizzelj
I should say that it leaked when the truck is off as well.
Old Dec 12, 2015 | 10:19 AM
bizzelj's Avatar
bizzelj
We're does the 1inch hose go to?
Old Dec 12, 2015 | 10:28 AM
bizzelj's Avatar
bizzelj
Just to be clear the waterpum is right below the thermostat were the lower radiator hose goes into and there is another hose that goes into it. So there is only two hoses that go into the waterpump correct?
Old Dec 12, 2015 | 10:38 AM
bizzelj's Avatar
bizzelj
Seems like it could be coming from were the lower radiator hose is secured to the radiator by those plastic clips as there is coolant all in there and when I push up on it more comes out and nothingn above that point is wet
Old Dec 12, 2015 | 03:03 PM
bizzelj's Avatar
bizzelj
Got the new hose back on now I'm trying to get the cac tube back in
Old Dec 12, 2015 | 05:12 PM
bizzelj's Avatar
bizzelj
well looks like maybe it fixed it not sure if there is enough coolant in there to fix it. gotta go in the morning and get some. how much coolant does it hold?
Old Dec 13, 2015 | 01:47 AM
run6.0run's Avatar
run6.0run
I'm assuming you have the banks cac tube setup?? Those are big for sure. Gotta wrestle the crap outta it to get it apart. It will NEVER blow off,, but dang!!!! Let me say I freakin hate the banks setup. It's nice I guess,, as long as you never have to touch it. Which you got a lesson as to why I can't stand aftermarket stuff.
