Better MPG
Old Feb 19, 2012 | 06:56 PM
dee004's Avatar
dee004
Originally Posted by texans
765 miles?? How big of a tank do you have? I think the normal tank is like 28.5 gal isn't it? that would be 26.8 MPG. No way I would buy that
Maybe the odometer is set to KM which is still a stretch even on my 65HP tow tune. I can get near that if I keep my foot out of it and risk carboning up the turbo. Not worth the hassle......
Old Feb 19, 2012 | 07:15 PM
texans's Avatar
texans
Originally Posted by 69cj
It wouldn't get 26 mpg falling off a cliff.
That has to be the funniest thing I read all week
Old Feb 19, 2012 | 07:35 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
regear the truck and you might get 2 mpg gain. trick is to get the truck final drive-line ratio back to near stock. your 37's are making the motor work harder than it was designed to.
I'm seeing 11 mpg city consistently with my 35's. I can do better...about 14-15 mpg city, but then the truck is just boring to drive.
Originally Posted by Sullid01
I lost about 1mpg with Matts SRL++. It is awesome though. Tires and lift kill you. Spending to save mpgs usually is a waste, ie no payback
I'm in the same spot....that's more because I can't keep my foot outta the skinny pedal...and the occasional clouds of black smoke that I see out the rear mirror at times
Old Feb 20, 2012 | 09:35 AM
run6.0run's Avatar
run6.0run
My truck has a 38 gal stock tank. I've gotten as high as 800mi out of a stock tank. Tailwind, and 58mph, no cruise control.
Old Feb 20, 2012 | 11:35 AM
cajunsuperduty's Avatar
cajunsuperduty
If your truck has over 4" of lift and you have 35" tires or larger and you are trying to get better than 13 mpg, you might just be a 6.0L owner. Hell I can't get better than 13 if I trailer my truck.
btm991
6.7L Power Stroke Diesel
18
Mar 7, 2013 12:51 PM
homr75
Aug 12, 2012 09:40 AM
R1F150
Computer Chips & Tuners
Apr 26, 2011 07:40 PM
Ford11
Jun 23, 2009 07:18 AM
cawatters
Dec 5, 2006 11:05 PM
